1967 RS runs 20 years later! - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 40 (permalink) Old Sep 9th, 12, 01:50 PM Thread Starter
I just wanted to introduce myself to this group. I started my Granada Gold 1967 RS coupe today for the first time in almost 20 years! For the last month or 2, I've been doing research and trying to figure out what to do to get it running safely. Thanks to this site I found a lot of info that was put to good use to get where I am today with this project.
The car is mostly original equipment. I've owned it since 1984 and my brother owned it for a few years before that. He found it in San Antonio and it was rust-free and pristine with 125,000 miles in a used car lot. He paid $4,900 for it back then. The 2-speed PG transmission was replaced by my brother when he bought the car to a 3-speed 350. Original engine is a 327 275hp with about 160k miles now but it fired right up as soon as I replaced the points. Sounds like it did the day I parked it in the garage and life got in the way. I put it away because it really needed suspension work and some underbody restoration that I couldn't afford. Now that it's cleaned up and running, I will start chipping away at the things necessary to get it drivable. It's still pretty clean with very little rust.
I did take a chance and run it around the block (slowly) with my 13 yr. old twin boys, who were elated too that we got it going.
I will post some pics and possibly video of the start-up soon but just wanted to finally join this forum and thank all of you for providing the help I needed to get this far.
Thanks and more to come!
trland is offline
post #2 of 40 (permalink) Old Sep 9th, 12, 02:47 PM
Re: 1967 RS runs 20 years later!
Welcome aboard!
Congrats on the successful relaunch. I, for one would love to see photos!
Check the brakes and fuel lines carefully and drive it!
Melrose RS is offline
post #3 of 40 (permalink) Old Sep 9th, 12, 03:41 PM Thread Starter
Thanks for the kind welcome. I will try to get pics up soon. Your RS is an inspiration!
trland is offline
post #4 of 40 (permalink) Old Sep 9th, 12, 04:01 PM Thread Starter
Here's my first attempt at pics. Pre-cleanup dust bucket and post cleanup with the boys ready for a ride! If the pics don't show up, I'll try again.
ID:	29976   Click image for larger version
ID:	29977   Click image for larger version
trland is offline
post #5 of 40 (permalink) Old Sep 9th, 12, 04:18 PM
69-Pace's Avatar
Congrats. Another deep sleeper awoken.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #6 of 40 (permalink) Old Sep 9th, 12, 04:42 PM
Congratulations, Mike.
A successful launch!
post #7 of 40 (permalink) Old Sep 9th, 12, 05:45 PM
Excellent! Looks very original!
post #8 of 40 (permalink) Old Sep 9th, 12, 06:14 PM Thread Starter
Thanks. I plan on keeping it as original as possible. Wish it still had the original Powerglide tranny but otherwise it's still pretty complete. Everything matches the trim tag and the VIN and partial VINs match. I don't have a partial VIN on the engine block but I read on the CRG site and this forum that not all '67s had that. The engine is coded as an MM made at the right time for the trim tag date and it still has the GM recall cables to secure the engine mounts which I assume would not be there if the engine had been removed/replaced. I believe I found that info on this forum too. You guys are a wealth of info!
trland is offline
post #9 of 40 (permalink) Old Sep 9th, 12, 06:42 PM
alex
Welcome aboard Mike I had a 67s/s350 4spd around 70/71 loved that car with one exception the 9 1/2 inch drum brakes just awfull to stop with anything that has any kind of real power. They didn,t have disc brake changeover kits in those days. You can,t beat a Chevy my 70 s/s sat about 25 yrs in the garage without running . I put in a fresh battery fresh gas a new set of points and condenser and she fired right up after about 4 cranks with the old motor oil still in her and not one tick. It was like i had shut her off the day before .I had to go through her from front to rear to make her road worthy but she ran.GOOD LUCK with your 67. Alex
ss27 is offline
post #10 of 40 (permalink) Old Sep 9th, 12, 06:42 PM
Just out of curiosity, what is the build date on the trim tag?
And for what its worth, swapping out the powerglide in mine was a huge improvement. The 327/275 needs more gears than just two in my opinion!
Sent from my iPhone using Autoguide
post #11 of 40 (permalink) Old Sep 9th, 12, 06:57 PM
harvey
Welcome, love to hear storyes like these good luck and happy motoring
pink panther is offline
post #12 of 40 (permalink) Old Sep 9th, 12, 07:15 PM Thread Starter
I do like the 3-speed. It ran great when I was driving it every day a long time ago. I've never owned a car with a powerglide so it's good to hear your opinion. I don't plan on selling it so it really doesn't matter for resale value.
Here is the complete trim tag decoding from auto decoder at theCamaro.com
I also checked it manually with the CRG pages. Please let me know if you see anything unusual.
Decode of your 1967 Camaro Trim Tag:02= February, 1967, the month car was built.A= First week of the month.F278= is a internal LOS Angeles Plant assembly code.12637= Deluxe interior coupe body style type.LOS= Vehicle was assembled at the Los Angeles, California assembly plant.16159= Unique body sequence number assigned at the assembly plant.711= Deluxe Gold bucket seat interior.Z= Bucket seats without headrests.G= Granada Gold lower body paint color.G= Granada Gold upper body color.
Breakdown of Group 1 Options:E= A01 Soft Ray tinted glass, all windows. Cost $30.55, total production = 34,752.
Breakdown of Group 2 Options:E= C60 Four-Season air conditioning, includes 61 amp alternator, HD radiator and temp controlled fan. Cost $356.00, total production = 28,226.M= M35 Powerglide 2-speed automatic transmission, price with L6 engine. Cost $194.35, total production = 122,727.M= M35 Powerglide 2-speed automatic transmission, price with V8 engine. Cost $194.35, total production = 122,727.M= M40 Turbo Hydra-Matic 400 3- speed automatic transmission - requires L34 or L35 Cost $226.45, total production = 1,453.G= D55 Console with floor mounted shifter, storage compartment, rear seat ashtray and courtesy light. Cost $47.40, total production = 129,477.
Breakdown of Group 3 Options:L= Z22 Rally Sport Package including Z21 option plus full width grill with concealed headlights, bright lower body side moldings, RS grille emblem (or SS when options combined), parking/turn signal lights located below front bumper, reverse lights located below bumper in rear. Cost $105.35, total production = 64,842.
Breakdown of Group 5 Options:B= V32 Rear bumper guards. Cost $9.50, total production = 35,029.
trland is offline
post #13 of 40 (permalink) Old Sep 9th, 12, 10:50 PM
Jeff Spicoli
GoCamaro27's Avatar
Welcome Mike. I'm very partial towards '67 Rally Sport cars, so it's really nice to see another one being brought back to life. This will also be a great project to involve your boys (I have two myself). I look forward to watching your project.
Relax, all right? My dad's a TV repairman, got an ultimate set of tools. I can fix it.
1967 Camaro RS ZL1 427/4 speed
1967 Camaro RS 327 L30 4 speed
1955 Bel Air 4-door, 350/TH700R4
1969 Camaro convertible X11 Indy 500 Pace Car, matching numbers 396/4 speed
1968 Camaro, Grotto Blue project car
1970 Camaro RS
My Mom's 1978 Lincoln Continental Mark V Diamond Jubilee Edition
2000 Rolls Royce Silver Seraph
GoCamaro27 is offline
post #14 of 40 (permalink) Old Sep 10th, 12, 09:26 AM
that's AWESOME
1968 Coupe, 327ci basketcase project
1986 Chevy Stepside, 305ci/300hp
JIM68 is offline
post #15 of 40 (permalink) Old Sep 10th, 12, 04:15 PM
Paul
Thumbs up Re: 1967 RS runs 20 years later!
Welcome to team camaro!!
1969 RS/SS DROPTOP is offline
