2000 coupe - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 11 (permalink) Old Sep 10th, 12, 11:00 AM Thread Starter
hans
2000 coupe
Hey,this comming weekend I'm flying from La. to NY. and will be driving back in my new 2000 camaro coupe. It was my fathers and has less than 50k,miles on it. It has also been put up for years since his death,waiting on legal b/s and my ability to retrieve it. Was wondering,all the reviews have been great so far and I plan on doing a thorough inspection and maintenance on it before the 1500 mile trip home but is there anything that you guys can think of that is a common problem with these cars. Any time sensitive parts that give out just because of age. ANY info would help, I own an old ford truck so do know a few things but not much about a newer camaro. I'm definitely going to keep it for as long as posible but for now want to make it back home. Thank y'all in advance
tiller83 is offline
post #2 of 11 (permalink) Old Sep 10th, 12, 11:11 AM
Re: 2000 coupe
I just sold one of my 69's and got a 2002 ss le, it's a well engineered car. One thing I've learned is the LS1 has a problem with water pump gaskets leaking. Also I have a slight oil leak which appears to be a valve cover, other than those two things all is fine.
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
nashcar is offline
post #3 of 11 (permalink) Old Sep 10th, 12, 01:00 PM
Re: 2000 coupe
I daily drive a 2002 Z28 and have had 2 other 4th gens as well. I recently sold my 98 with 184,xxx on it and it ran like a champ. They are well built automobiles (if you can get past the plastic interior - doesn't bother me).
If the car has been well maintained it should make the journey without a problem.
And Welcome to Team Camaro!
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797-Z...
"Politics is the art of looking for trouble, finding it whether it exists or not, diagnosing it incorrectly and applying the wrong remedy" - Sir Ernest Benn
PowerWindows is offline
post #4 of 11 (permalink) Old Sep 10th, 12, 01:23 PM
Vintage 68's Avatar
Wink Re: 2000 coupe
Those are usually good vehicles and should be just fine.
But ... before you go anywhere with a vehicle that's been sitting;
- change the oil and filter before you drive it far - there's a lot of 'stuff' in it by now you want gone.
- change the fuel filter (and grab a spare) before you drive home
- fill the tank with a 'fresh' tank of fuel and maybe a 'dryer' additive if it's been sitting where moisture could have entered/accumulated in tank.
- obviously check all the fluid levels very carefully.
- check the brakes and tires
- replace the wiper blades (and fill washer) before you need them
- buy some spare fuses
- take a GOOD flashlight
1968 Convertible
Some trucks
Vintage 68 is offline
post #5 of 11 (permalink) Old Sep 10th, 12, 04:08 PM
Steiner
Re: 2000 coupe
I'd go ahead and put a new battery in it. They go bad with time not use usually plus those side post terminals are prone to corroding and rotting out.
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 11 (permalink) Old Sep 10th, 12, 04:24 PM
Paul
Thumbs up Re: 2000 coupe
Welcome to team camaro!!
1969 RS/SS DROPTOP is offline
post #7 of 11 (permalink) Old Sep 10th, 12, 05:19 PM
Re: 2000 coupe
Welcome to the Club, Hans.
Good suggestions given. Mine sre check the tires for dry rot cracks. If cracked severly, replace them as they will get heated and may have a blowout. Keep tires inflated at least to 32 PSI.
Next, remove the radiator cap and check the coolant. If sludge is on the cap, change the coolant, having a flush performed would be worth the money spent before the trip.
Along with the flashlight, take a bottle of waterless hand cleaner and a sacrifical towel for a rag/hand cleaner.
My condolences on Father's death. He'll be with you on your trip as your guardian angel in case anything happens.
post #8 of 11 (permalink) Old Sep 10th, 12, 05:40 PM
mike
Re: 2000 coupe
get a garmin , grab your cell , and check the normal things and hit the road . 50 K , thats still a puppy . my 01 z ( that i brought brand new with 3 miles on it ) has north of 135 k and is still a fully functioning car that everything works on . i still get a kick out of driving it and it still looks great .
twozs is offline
post #9 of 11 (permalink) Old Sep 11th, 12, 10:35 AM
Re: 2000 coupe
Also, if you do change coolant be aware that you can't mix orange DexCool with regular green coolant.
post #10 of 11 (permalink) Old Sep 11th, 12, 11:05 AM Thread Starter
hans
Re: 2000 coupe
Thank you all for the welcome and the info.Yes the batterie is dead but will start and run with a jump,according to my brothers. Was going to change all fluids and belt(s). Also check hoses and brakes. They say the tires are good,it was in a garrage untill this last spring. I know that the 90's truck engines had a problem with a heater hose addaptor that would rot and was(is) a major pain to replace. Was hoping there were no suprises like that in store. Sounds so far like it's going to be a great car, will just take some getting used to. My truck sets up very high and I enjoy the visibility, but it's old and I've put it through hell. I will certainly enjoy the fuel milage and a/c in the camaro along with less maintenance and cheeper tires. ? what tires have y'all found are best for these cars ??. thanks again.
tiller83 is offline
post #11 of 11 (permalink) Old Sep 11th, 12, 05:39 PM
Re: 2000 coupe
Talk to Discount Tire, a sponsor here.
