How Y'all Doing - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 11 (permalink) Old Jan 18th, 13, 07:03 AM Thread Starter
How Y'all Doing
I'm from Ga. (30 miles south of Atlanta)..I'm retired and this will be my first camaro..I am neither a paint/body man nor "good"mechanic but I do know what a spark plug is(i am the official gopher)..just got this 67 RS 327 (hope these pic come up)..It was restored in 2006.. we went over it with a magnet as best we could before buying it..It's as solid as the po said..but the trunk has water in it when it rained and/or washed..thought it might be the rubber seal under trunk lid but found where po replaced that in 06..My mech.said it could be back window weather strip which was not replaced.
What's the best way to check to see where it's coming in..
Thanks..Attachment 31858
Attachment 31859
Attachment 31860
Attachment 31861 Jim-Bob
Jim-Bob is offline
post #2 of 11 (permalink) Old Jan 18th, 13, 08:09 AM
Jeff
Re: How Y'all Doing
Good looking car Jim-Bob, welcome to TC....
fordpowerjoke is offline
post #3 of 11 (permalink) Old Jan 18th, 13, 08:20 AM
Carl
67Carl's Avatar
Re: How Y'all Doing
Welcome! And congratulations for buying the right year! My '67 (originally butternut yellow like yours) has the same water issue. unfortunately this is a fairly common problem on first gens. It's the bottom window channel, likely the left and right corners, rusted out. Use the search feature and type in "rear window channel rust" and you'll get a lot of info.
1967 350, Hurst TKO 600 5 speed, 12 bolt 3:55 posi, RS added
67Carl is offline
post #4 of 11 (permalink) Old Jan 18th, 13, 08:25 AM
George
Gbauer's Avatar
Re: How Y'all Doing
Welcome! The car looks to be in excellent shape! Nice find!
I can't help but read your post with a southern accent in my head.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #5 of 11 (permalink) Old Jan 18th, 13, 08:28 AM
Vintage 68's Avatar
Thumbs up Re: How Y'all Doing
Welcome to Team CAMARO Jim
Nice looking 67
Actually it was a case of 'deja vu' for me looking at the pictures
If that car was an RS/SS350and came out of the LA Calif. area it would of had me calling you - looks and has the identical options to one of the 1st 67's I bought in the early 70's and let go WAY to soon ...
Originally Posted by Jim-Bob View Post
I..My mech.said it could be back window weather strip which was not replaced.
Thanks... Jim-Bob
Your 'Mech.' is close - but, there is no 'weather strip' for the rear window, they are just set in on sealer just a front windshield would be.
But - it may still actually be the rear window leaking, are prone to rusting and leaking in the lower window channel.
The 'best' way I know of is - to get in the trunk with a good flashlight and have someone (you trust ) run water around either side and slightly up the rear window while you keep a watch for where it's coming in - you'll be able to easily see it if there are rust issues
These vehicles are very prone to debris getting/being stuck in the lower window channel, which will retain moisture and lead to rust - that leads leaks into trunk - and rusted trunk pans ...
The best fix is to remove the rear window and repair the rusted areas prior to reinstalling it correctly. There is little to be gained by trying (short long term) to apply silicone or other type sealers around the window or trim when trying to stop this leaking it looks like heck and doesn't work the majority of time.
1968 Convertible
Some trucks
Vintage 68 is offline
post #6 of 11 (permalink) Old Jan 18th, 13, 12:36 PM
Paul
Welcome to team camaro!!
1969 RS/SS DROPTOP is offline
post #7 of 11 (permalink) Old Jan 18th, 13, 02:33 PM
Re: How Y'all Doing
Welcome to the Club, Jim-Bob.
Nice ride, indeed.
Like John suggests, Vintage 68, get the rear window fixed, it will only get worse.
With a vinyl top, it will be alittle harder to fix, but, can be done. Use a window seal repair kit.
Buy the window clip tool to remove and install molding, well worth the $5, even if you only use it once, er, one job.
Might consider having a pro do it after fixing the sheet metal damage underneath.
post #8 of 11 (permalink) Old Jan 18th, 13, 03:39 PM
harvey
Re: How Y'all Doing
Welcome, cool ride
pink panther is offline
post #9 of 11 (permalink) Old Jan 18th, 13, 03:49 PM
Banned
Rob
satz28's Avatar
Welcome to the club!
satz28 is offline
post #10 of 11 (permalink) Old Jan 18th, 13, 05:04 PM
Ron
Re: How Y'all Doing
Welcome Jim Bob
These guys no there stuff on here so your in good hands.
68 PW,PS,PB,AC,v8,2speed on column,
wolfe is offline
post #11 of 11 (permalink) Old Jan 19th, 13, 10:01 AM Thread Starter
Re: How Y'all Doing
'preciate all the welcomes..especially the info from Vintage 68 and Everett.. I'll try all those things y'all mentioned but I thought we looked that area over real good..the bottom of the pkg tray, etc for rust..didnt see any..guess this is down in there where you cant see huh??
Say Everett..do you happened to visit the Camaro Forum? the avatar is a rescue dawg??
Jim-Bob is offline
