Hello from Canada - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 16 (permalink) Old Jan 29th, 13, 06:42 PM Thread Starter
Laurie
Hello from Canada
Hello Everyone,
I am here reading as much as I can as I am in the process of buying a 1968 convertible Camaro. I hope to ask for some advice in the near future. For now I would like to post some info on the car I am looking to buy.
1968 Chevrolet Camaro Convertible
- 454 4 bolt mains .030 over, block decked, align honed, tanked and all burs removed
- 7/16 Eagle connecting Rods rated to hold 800hp
- Speed Pro Forged Pistons with teflon coated skirts and moly rings (10.4:1 compression ratio with 118cc open chamber heads)
-High volume oil pump with matching pick up
- Milodon stock replacement oil pan
-Balanced rotating assembly (crankshaft, rods, Pistons, damper and flywheel
- GM Iron rectangular port open chamber cylinder heads, CNC ported and polished by Mercury Marine
- 2.25 intake valves with reduced stem diameter for higher airflow rate
- Valve springs for hydraulic roller cam / matching retainers and valve locks
- Comp Cams hydraulic roller camshaft (advanced 4 degrees at crankshaft)
- Double roller timing chain with cam button bearing and torrington thrust bearing for correct camshaft endplay
- Comp Cams 3/8 push rods rated for hydraulic roller cam
- Comp Cams Pro Magnum Roller Rockers
- Factory cast iron exhaust manifolds
- Single muffler is two pipes in- two pipes out. Believe it or not this is COPO exhaust from the factory
- 540 horsepower sounds mean even through this stock exhaust
- Heat riser installed with no butterfly (used as a spacer for correct exhaust distance)
- MSD Distributor and MSD 6AL Ignition Box with canister type Blaster Ignition Coil.
- Holley 4779-9 750CFM Double Pumper Carburetor with proper factory GM fuel line and Y-Block
- 14 inch proper factory high performance air cleaner
- Rebuilt power steering pump and steering box
- Big block sway bay, BB coil springs
- New upper and lower control arms with new control arm bushings and ball joints
- New inner and outer tie rods
- All new sub-frame body mounts
- all new fuel lines and fuel tank and sending unit
-All new brake lines, front disc brakes, master cylinder, spindles, calipers, brake cylinders, rotors and drums
- New multi leaf springs in rear
- New Moser Engineering reproduction 12 bolt posi trac rear end with 3.42:1 gear ratio, Yukon rear axles
- All floor metal new stampings
- Both rocker panels new complete units
- quarters, doors, fenders, hood, rear panel, inner wheel houses, all new panels, no filler
- media blasted body before panels installed
- all chrome re-plated and or
- original side glass, new front glass
- new manual top, top frame completely disassembled, sandblasted and re assembled.
- have Boot cover brand new in box with all new clips
- New complete interior, rug, panels etc...
- new door handles, winders etc
- New chrome, bumpers, hood stacks outer door handles, everything
- New grill assembly, lights, marker lenses, chrome bezels, emblems
- New BFG tires, Chevrolet Rally rims (including spare in trunk
- restored original trunk jack
- - 621 belhousing with new fork
- Sony AM/FM mp3 player in glove box
- Original 1968 Camaro GM AM radio in dash
- Aftermarket Tach and guages
- Hurst 4 speed shifter
- GM rosewood steering wheel
- rebuilt steering column (new bearings)
- new 1968 GM correct small size keys, one key fits all doors, glove box, trunks and ignition cylinder.
- All new key barrels
- Big block heater core and heater box
- full restoration every nut and bolt
- Lemans blue exterior / black top / black interior
THEKID is offline
post #2 of 16 (permalink) Old Jan 29th, 13, 08:25 PM
69z28freak's Avatar
Re: Hello from Canada
Welcome Laurie. What part of Canada do you live in? Sounds like a nice car. Woyld love to see some pictures.
Grandma, 69.5, Z/28 Finally Done! Well almost...
My Build Thread
69z28freak is offline
post #3 of 16 (permalink) Old Jan 30th, 13, 03:20 AM Thread Starter
Laurie
I am from Winnipeg, Manitoba. Here is a pic.
THEKID is offline
post #4 of 16 (permalink) Old Jan 30th, 13, 04:45 AM
Paul
Thumbs up Re: Hello from Canada
Welcome to team camaro!!
1969 RS/SS DROPTOP is offline
post #5 of 16 (permalink) Old Jan 30th, 13, 06:16 AM
Welcome, Laurie
Correct year and enjoy it!
Thanks for sharing.
post #6 of 16 (permalink) Old Jan 30th, 13, 07:46 AM Thread Starter
Laurie
Thank-you all for the warm welcome.
THEKID is offline
post #7 of 16 (permalink) Old Jan 30th, 13, 11:21 AM
Milt
Milt's 68 SS/RS 396's Avatar
Welcome to Team Camaro. That is an awesome looking car. More pics
Go big, or stay Home!
Milt's 68 SS/RS 396 is online now
post #8 of 16 (permalink) Old Jan 30th, 13, 11:34 AM
Hey, welcome to the TC Crew.
Looks like ya got real turnkey unit there...just fill her up and take off.
The owner before you really went overboard with the restore...good for you, eh?
I got the same mid kid drop top as you...bestest year!
Ever make it down to Kenora on Lake of the Woods?
capt
captcanuck68 is offline
post #9 of 16 (permalink) Old Jan 30th, 13, 12:10 PM
Vince
vincevs's Avatar
Here is some more information from Jim M... If you are in the market, this would be a great car.
https://www.camaros.net/forums/showthread.php?t=216062
Vince
69 Base Coupe "The Wrecker" Project -
67 rs/SS L48 4spd Convertible -
- SOLD
vincevs is offline
post #10 of 16 (permalink) Old Jan 30th, 13, 04:42 PM Thread Starter
Laurie
Fish on Lake of the woods often. Where abouts are you?
THEKID is offline
post #11 of 16 (permalink) Old Jan 30th, 13, 04:43 PM Thread Starter
Laurie
I sent him an email but no reply.
THEKID is offline
post #12 of 16 (permalink) Old Jan 30th, 13, 05:48 PM
69z28freak's Avatar
Wow nice car! I almost bought one just like it many years ago. Still wish I had.
My Build Thread
post #13 of 16 (permalink) Old Jan 31st, 13, 04:34 AM
Orig from that area...now fish L. Erie, eh? Check out the Kenora car show they have in the bay once a year.
Heard the mosquitos gave you a hard time this past summer?
Crazy winter down here this year! Spring/winter/spring /winter.
capt
post #14 of 16 (permalink) Old Jan 31st, 13, 08:23 AM Thread Starter
Laurie
Can you put me in touch with Jim?
THEKID is offline
post #15 of 16 (permalink) Old Jan 31st, 13, 09:54 AM
Vince
vincevs's Avatar
Try him here...
http://www.firstgens.com/
Vince
- SOLD
vincevs is offline
