Tilted fuel pressure regulator - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 3 (permalink) Old Mar 19th, 14, 06:15 PM Thread Starter
Curt
Hey guys, I'm currently dry fitting my new intake and carb setup on the bench and I'm into the plumbing. In making the hoses I am running into a prob. My fuel pressur regulator takes the feed through the bottom and I can't squeeze a fitting in as it will hit the manifold. If I tilt the regulator a bit on the fitting, it'll fit.
Now my question is...Does it affect the feed/pressure if I do this? Its a Holley, 1-9 psi coming from a mechanical pump.
Thanks in advance
1sw8 67 is offline
post #2 of 3 (permalink) Old Mar 19th, 14, 07:43 PM
Re: Tilted fuel pressure regulator
Orientation of the fuel pressure regulator should not effect functionality at all. Your other option is to use a 90 degree fitting coming up into the bottom of the regulator.
NH69Z28RS is offline
post #3 of 3 (permalink) Old Mar 20th, 14, 04:56 PM Thread Starter
Curt
Much appreciated my man...the 90 will be hunted tomorrow. First nice day of the year up here and the first run of the season was today
1sw8 67 is offline
