New 1969 camaro owner - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 20 (permalink) Old May 14th, 14, 01:02 PM Thread Starter
Ray
Talking New 1969 camaro owner
Hello fellow car lovers , just a quick intro . A week ago i was able to make my dream come true , been looking/saving a few dollars a month for close to 16 years , it has happened . found and tracked the owner down , the car is a very nice surviver base model , very base V8 4 speed single leaf manual steering & brakes . Dover white black interior , looks to be 95% original , intake and carb were replaced , but orig. were left in the trunk .
will be needing some help on the ignition soon , seems to have had the resistor wire fry at some point and then it was rigged up to start with a jumper wire straight from the starter to battery, you actually have to touch the wire to the batt ! a few other things like the neutral safety switch was cut and bypassed ! going to try and get it all back factory .
Willis209 is offline
post #2 of 20 (permalink) Old May 14th, 14, 01:05 PM
Re: New 1969 camaro owner
Nice looking early car. 327, 4 speed with no other options.
Might as well take more pictures and post the trim tag and vin.....you will soon get more replies for them.
Post updates.
You Can't Fake Indifference
69 Camaro Convertible
57 Chevrolet Nomad
Jeeps
buzzworth is offline
post #3 of 20 (permalink) Old May 14th, 14, 01:13 PM Thread Starter
Ray
post #4 of 20 (permalink) Old May 14th, 14, 01:15 PM Thread Starter
Ray
thanks buzzworth , yeah more pics are on the way but here is some video
post #5 of 20 (permalink) Old May 14th, 14, 02:36 PM
69-Pace's Avatar
Nice save Ray. BTW the second video link is "private" on youtube and can not play for those not granted permission. I can delete it from the posting if it was not intended to be public.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #6 of 20 (permalink) Old May 14th, 14, 03:00 PM
Joe
Welcome Ray and nice find. Considering you may have some ignition issues and other wire problems you may want to consider getting new harnesses for piece of mind.
http://www.americanautowire.com/shop...ROLET%3BCAMARO
Z282NV
1969 Camaro
Z282NV is offline
post #7 of 20 (permalink) Old May 14th, 14, 03:44 PM Thread Starter
Ray
thank you Joe and Brian just fixed that video , should be public
post #8 of 20 (permalink) Old May 14th, 14, 05:21 PM
Charlie
Hey Ray,
Very nice car and follow through on your 16 year Camaro savings plan. Now continue that plan with your retirement account!
Say, which 4 speed transmission is in the car and I assume you have a 10 bolt limited slip rear end with mono leafs, right?
Enjoy.
Charlie
Edmonds, WA
1969 Camaro SS Vert LS1 T56
camaromaniac is offline
post #9 of 20 (permalink) Old May 14th, 14, 05:50 PM Thread Starter
Ray
Charlie yeah this was my car fund , retirement is still in the bank . its saginaw and yes 10 bolt have not inspected to see if its limited slip , im assuming its open since it was such a base model . will post pics of everything soon .
post #10 of 20 (permalink) Old May 14th, 14, 08:14 PM
Vince
vincevs's Avatar
Looks like a great car! Congrats.
Sent from my iPhone
Vince
69 Base Coupe "The Wrecker" Project -
67 rs/SS L48 4spd Convertible -
- SOLD
vincevs is offline
post #11 of 20 (permalink) Old May 14th, 14, 10:32 PM Thread Starter
Ray
Unhappy Re: New 1969 camaro owner
Here is a video of some of the wiring issues
Last edited by 69-Pace; May 15th, 14 at 01:19 PM. Reason: fixed link so it would embed
post #12 of 20 (permalink) Old May 15th, 14, 01:04 PM
T.C.
Welcome Ray! It looks nice.
T.C.
BMR Suspension is offline
post #13 of 20 (permalink) Old May 15th, 14, 01:09 PM Thread Starter
Ray
Thanks T.C waiting on a new harness recommended by Joe , then i will be in need of some help to get it back looking orig. planning on putting the orig carb and intake back as well as all the wiring
post #14 of 20 (permalink) Old May 15th, 14, 01:28 PM
69-Pace's Avatar
So yeah soup sandwich wiring wise but could be worse. The current carburetor uses an electric choke, the original used a divorced choke so it will not be needed. I think it is the red lead in your video that is spliced into the wiper line. The power to the aftermarket gauge pac - the blue wire - seems to be hitting a 20 or 30 amp circuit breaker mounted under the dash. The NSS override is typical and not so cool.
The American Autowire Factory Fit line is top notch and will eliminate all your issues. I assume you ordered a full harness? If you wish to retain the aftermarket gauges you will have to use the wiring there already, or convert the existing non console gauge service stub to a factory style gauge (sawtooth) gauge pac and console. It is an easy conversion and might as well do it all at once
69-Pace is offline
post #15 of 20 (permalink) Old May 15th, 14, 01:47 PM Thread Starter
Ray
planning on removing the aftermarket gauge pac , and yeah the NSS will be addressed , i did not order the full harness .
I ordered http://www.heartbeatcitycamaro.com/s...-harness-1969/
please note this wiring is all new to me.
