Hi All - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 9 (permalink) Old Jun 26th, 18, 09:13 AM Thread Starter
Send a message via AIM to hotrodbaker
Hi All
New member today, my name is Mike. Working on my 67 ragtop and wishing i was driving it. Anyone know why the shifter I have mounted to my Saginaw 4 speed uses the holes that should be for cross member mount. I can't figure how to mount it and the new hurst linkage has the same mount that uses the only 2 holes that i think should be to mount it in the car. Any help is appreciated!
hotrodbaker is offline
post #2 of 9 (permalink) Old Jun 27th, 18, 04:36 AM
Greg
pittpens24's Avatar
Re: Hi All
I have had a Hurst shifter in both a saginaw and muncie trans and they both mounted to the side of the trans with the cross-member mounting to the bottom.
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #3 of 9 (permalink) Old Jun 27th, 18, 05:05 AM
Re: Hi All
Hey, Mike, could be design time of the shifters
I've had both types/brands mounting either by a plate under trans mount and the other mounted on the side with a plate and an U-clamp around tailshaft housing.
Doing a good job is like peeing in your dark pants Ö you get a warm feeling, but nobody notices
post #4 of 9 (permalink) Old Jun 27th, 18, 05:10 AM
69-Pace's Avatar
Re: Hi All
Hey Mike - Yeah sounds like the previous owner had a few too many good ideas.
Open your copy of the 1967 AIM and look at how the cross member and the factory shifter options were supposed to be mounted to the sub-frame and the shifter to the transmission body. Not sure what shifter - factory - aftermarket you currently have.
I would start by trying to get the cross member then the current shifter installed correctly, then once at that square one, swap out your shifter for the new Hurst.
Hurst aftermarket shifters had particular kits for particular trans/engine/years so make sure all of your stuff is of the same year/options before tearing into it to save some long periods of transmission depression.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #5 of 9 (permalink) Old Jun 27th, 18, 03:03 PM
Garth
Re: Hi All
Good to see ya back, Brian !!
Welcome aboard, Mike !
Garfields Maro is online now
post #6 of 9 (permalink) Old Jun 27th, 18, 04:21 PM
ray
Re: Hi All
Welcome Mike.
carcrazy615 is offline
post #7 of 9 (permalink) Old Jun 27th, 18, 05:31 PM
69-Pace's Avatar
Re: Hi All
Good to be back.
And Welcome Mike. I'll also add the question to the above... are you able to shift the vehicle with it mounted to the crossmember? If I remember right 67 and 68 Hurst aftermarket used U clamps on the transmission tail housing. Many folks made or bought specially made mounting plates to avoid the U clamps. Maybe you have a hybrid of one of those?
69-Pace is offline
post #8 of 9 (permalink) Old Jun 29th, 18, 07:44 AM
Apprentice
Darrell
Re: Hi All
Just info on my set up. 67 SS/RS BBC M21 with Hurst shifter
Shifter mounts to a bracket on the driver side of the trans.
This bracket (think "L" shape) mounts in between the trans tail shaft and trans mount (two bolts). A "U" clamp mounts around the tail housing to give the bracket stability.
Please don't ask how I had to modify this set up when I added a Gear Vendors overdrive...
hope it sort of helps
Fly Low and Avoid the Radar
blowamouse is offline
post #9 of 9 (permalink) Old Jun 29th, 18, 08:02 PM Thread Starter
Re: Hi All
Thanks for the tips. I have the l shaped bracket and it sandwiches between the trans and the crossmember mount with the ring around the tail.
