Returning Member from 2001 - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
 2Likes
  • 2 Post By Kiowa
post #1 of 10 (permalink) Old Oct 6th, 18, 09:46 AM Thread Starter
Probationer
Greeting from central Texas, After not logging in for a long time I have renewed my login. Now that I am retired and have more time on my hands I'm planning on doing some upgrades to my 1967 (clone) SS 350 convertible. The cooling system is my first priority. I look forward sharing knowledge with everybody on the forums.
Kiowa is offline
post #2 of 10 (permalink) Old Oct 6th, 18, 11:08 AM
69-Pace's Avatar
Re: Returning Member from 2001
Welcome back. What cooling issues are you having?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 10 (permalink) Old Oct 6th, 18, 11:58 AM
Are you near Lake Kiowa? If you are I am just south of you.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #4 of 10 (permalink) Old Oct 6th, 18, 03:59 PM Thread Starter
Probationer
Thanks, I have stock 2 row radiator that is leaking. I was thinking of up grading to an new aluminum Rad, I'am considering the Cold Case that has 2 large rows rather than 3 or 4 rows, they say the 2 large rows cools better. I am also trying decide if I want to go with the electric cooling fan and ditch the mechanical one. I also want up grade the water pump to higher performance pump. The car is just a weekend cruiser. Do you have any experience there that you could offer?
Kiowa is offline
post #5 of 10 (permalink) Old Oct 6th, 18, 04:07 PM Thread Starter
Probationer
Hi Don, No I'm north of Austin, Belton Tx. The Kiowa is in reference to the US Army Helicopter OH-58D Kiowa Warrior that I worked as a mechanic for many years.
130fe and dhutton like this.
Kiowa is offline
post #6 of 10 (permalink) Old Oct 6th, 18, 05:42 PM
Vega$69's Avatar
If the radiator you have now is doing the job why not just have it repaired?
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #7 of 10 (permalink) Old Oct 7th, 18, 09:23 AM Thread Starter
Probationer
It gets pretty hot here in Texas, looking to upgrade the system.
Kiowa is offline
post #8 of 10 (permalink) Old Nov 7th, 18, 07:07 PM
Probationer
Welcome back! I hope you can have your issues fixed as soon as possible.
jeanamstertadt is offline
post #9 of 10 (permalink) Old Nov 7th, 18, 09:06 PM
Stewart water pumps are top notch. The edelbrock isn’t far behind. A clutch fan with proper shroud will adequately cool any car. Use a big electric with a a PWM controller for wow factor. If you use an aluminum radiator make sure all your grounds are solid. Battery to engine. Engine to frame frame to body. Body to battery.
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #10 of 10 (permalink) Old Nov 8th, 18, 02:35 AM
Brett
Welcome back from a fellow Texan! I'm in Leander. I bought a Griffin large two row that you speak of and yes, I think large tubes in a two row cools better than a three or four row. At least I've seen better efficiency in mine. I also went with a stock clutch fan with a shroud and I like it as well. All ground straps connected like Steve recommends. I like original, but you are correct about our Texas summers and if you want to get more efficient cooling, the large two row is definitely a good upgrade.
Brett......
1969 SS 396 X66 - RS Conversion - TKO600 - 3.73 Posi - Paint Code 71-LeMans Blue
Brettallen59 is offline
