van nuys 69 with no drivetrain - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 3 (permalink) Old Nov 15th, 06, 07:42 PM Thread Starter
hi just bought a 69 hugger orange with blk top is there yet any way to find out what engine or trans came out in it.
troy3820 is offline
post #2 of 3 (permalink) Old Nov 15th, 06, 08:57 PM
"Tri-Tip"
Gary L's Avatar
Re: van nuys 69 with no drivetrain
Welcome to Team Camaro. Many VN cars have a build sheet above the gas tank. That may be your best bet. Many clues can get you close. Such as if the heater blower cover has outlets in the middle (BB) or engine end (SB) of the cover. If it was a manual trans car, is the speedometer cable on the driver (302,350,396) or passenger side (307,6 cyl.) of the steering column. Some engines can be eliminated by these clues. A 302 setup is going to look like an 350/300 setup, but not like a 307 or 6 cylinder setup. If it has the original differential, a 12 bolt will eliminate a 307 or 6 cylinder unless it had rear disk brakes. The engine frame brackets are different for BB and SB, if they are still there and orginal. Just some thoughts to get started with.
Gary L is offline
post #3 of 3 (permalink) Old Nov 15th, 06, 09:17 PM
I ckd my 69 Van Nuys car and there was no build sheet. How many fuel lines? Rear exhaust plate? How many leafs? How about front spring tags or discs? These items can get you closer to a dtermination? How about a pic? and cowl tag vin and axle numbers?
TOM BARKLEY is offline
Need help with 69 Numbers Matching Low 6Fo What's it worth? 19 Oct 13th, 06 11:01 PM
69 or 70 block kinsmd69 Restoration Corner 0 Oct 4th, 06 08:41 AM
Carb Dates DZ Fool Tag Team 16 Apr 2nd, 06 11:44 AM
69' Van Nuys Z burntbunz Tag Team 24 May 2nd, 05 01:32 PM
S Codes on '69 Van Nuys Cars Chuck L Tag Team 9 Apr 30th, 05 11:19 AM
