!969 Tunnel Hole - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 10 (permalink) Old Jan 8th, 07, 09:11 PM Thread Starter
Angry !969 Tunnel Hole
Iam a new guy with a 69 Z28...Trim tag matches assembly date, and options on the car as a true x33 Z car.
DZ 302 also has matching VIN, correct build date that matches block, carb AND rear end. The car has everything a Original Z28 should have, including the correct looking hole in firewall and bellows for clutch pedal.
Maybe im paranoid, but when going to tighten my Hurst Comp shift lever, I noticed that my hump tranny tunnel hole is jagged in some areas and not really smooth at all. It doesent look like an amatuer cut the hole, but I would have thought that GM used a punch or a jig to cut their holes.
If anyone has any thoughts, or has seen a similar ragged edge on a real 4 speed car I could use the reaasurance...Thanks Pat
pharri6914 is offline
post #2 of 10 (permalink) Old Jan 8th, 07, 09:34 PM
Re: !969 Tunnel Hole
A very belated welcome!
Camaro buds until the end!!!
Camaro Dave is offline
post #3 of 10 (permalink) Old Jan 9th, 07, 03:35 AM
Pretty sure the 4 speed holes on 69's were cut with a torch at the factory. Seems odd, but I almost positive that's how they did them.
buenymayor is offline
post #4 of 10 (permalink) Old Jan 9th, 07, 05:01 AM
Jerome
Welcome pharri 6914 ,I don't know the answer to that question,but the documention you explained ,I'm sure your ok ....good question ,does not belong in welcome wagon, you prob. will get answered but try in the resto forum,I would be intresed to see, I am sure Brian knows what ,my car is a manual trans car and has a punched hole and a doubler spot welded around defenitly factory...Good luck and have fun with your friend ...Happy Motoring
1972 Nova SS , 350, Auto, AC, Survivor
68Lemans blue is offline
post #5 of 10 (permalink) Old Jan 9th, 07, 06:32 AM
This is discussed here a lot, if you search "shifter hole torch" you'll get a ton of info. Here's one.
https://www.camaros.net/forums/showth...ght=hole+torch
Eric
Eric Kammerer is offline
post #6 of 10 (permalink) Old Jan 9th, 07, 06:48 AM
Gary
Short answer....yes.
For 69, a template was placed over the hump, and they used a torch on the line to cut out the manual floor shift opening. There was no reinforcement plate spotted to the underside of the opening, as was done in earlier years.
Unreal is offline
post #7 of 10 (permalink) Old Jan 9th, 07, 07:54 AM
Gary
Well, I just went back and re-read JohnZ's comments from several years ago. I stand corrected.......According to John, who was there, at least some 69s had the reinforcement plate. Maybe all Z/28, as they were all 4 speeds.
Unreal is offline
post #8 of 10 (permalink) Old Jan 9th, 07, 10:38 AM
William
William's Avatar
Nope, all Z/28s had the torch-cut hole.
Reinforcement plates were used on 3-speeds.
William
CRG
William is offline
post #9 of 10 (permalink) Old Jan 9th, 07, 11:22 AM Thread Starter
Thanks to all for their responses..That sick feeling I had is gone now...
Would I hurt any value by cleaning up the ragged-ness with a flat file or small grinder?
Pat
post #10 of 10 (permalink) Old Jan 9th, 07, 12:49 PM
Andrew
Andrew69's Avatar
My car has it too. As you can see from the comments these holes were cut with a torch. That torch cut hole should be viewed upon with pride; like a scar earned in a fight. Don't mess with it, you can never get it back (just my opinion).
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
RS Conversion on 1969 SS Coupe Camaro camaro350 Camaro Tech 31 May 13th, 07 07:57 PM
Tunnel Hole Location / Size for 68 4speed? emdoller Transmission & Driveline 3 Mar 13th, 06 09:07 AM
4 speed shifter hole in tunnel bilodeaulynn Tag Team 11 Mar 21st, 05 01:46 PM
Shifter hole in trans. tunnel 67 Plum Transmission & Driveline 1 Dec 2nd, 03 02:57 AM
4 SPEED HOLE IN TUNNEL 3DUDE Tech 2000 5 Feb 25th, 01 06:26 PM
