Adding Procharger to my Retrotek system - Team Camaro Tech
post #1 of 1 (permalink) Old Jan 22nd, 10, 09:17 PM Thread Starter
Bob
MileHigh69's Avatar
I have a 454 with a Retrotek stage 2 system. I am adding a Procharger D1SC system. I currently have a Tanks Inc , in tank fuel pump. My pump has the following rating. 54 GPH @ 40 PSI, 50 GPH @ 50 PSI, 48 GPH @ 60 PSI.
Is this enough for this setup? I also know I need to run a return line back from the front. Currently I loop it outside the tank and back in. What size line should the fuel and return line be? Is the stock fuel line big enough? I also need to install a ignition system with a electronic retard. Which system would be good for this? Thanks for any advice.
_______________________________
69 Camaro, Air Ride Suspension,
Procharged HO 454, 700R4, 12 bolt with Yukon axles, 3:73 gears posi, Pypes 2.5" X pipe with Borla XS mufflers. Retrotek Speed EFI, Ridetech suspension.
Rushforth rated X with Toyo tires. MSD 6 ignition.
Wilwood 6 piston Dynalite disc brakes with Hydratech booster.
MileHigh69 is offline
