Edelbrock Carb Intake for the LS - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 30th, 10, 05:54 PM Thread Starter
Dee
Have a '69 with a cowl hood. Thinking of going fuel injected LS but want to keep the air intake through the cowl hood. Has anyone used the Edelbrock carb intake and drilled/tapped the injector bosses to run EFI?
Sounds cool and would allow me to use the cowl intake. Any info out there?
Thanks,
1967 RS/SS350 Camaro (mostly stock)
1969 RS/SS Camaro (being improved!)
1967 Plum is offline
post #2 of 5 (permalink) Old Feb 2nd, 10, 06:49 PM Thread Starter
Dee
Re: Edelbrock Carb Intake for the LS
Guess no one has done this or knows of it being done????
post #3 of 5 (permalink) Old Feb 2nd, 10, 07:05 PM
Jeremiah
You can buy them already drilled from GMPP, Edelbrock and others. A few guys locally are running them with 105mm throttle bodys and 90 degree elbows with great results. You could do the same thing without the elbow but a 4500 style throttle body will be expensive. You should plan on having someone touch up the tune afterward and also plan on aftermarket fuel rails and regulator.
I have heard of very impressive top end gains but your going to lose some low end also. If your running a stick shift or have a stall it shouldnt be an issue.
69 Z/28, red/white stripe, black houndstoot with docs.
Jeremiah is offline
post #4 of 5 (permalink) Old Feb 2nd, 10, 07:26 PM
Jeremiah
Is this what your talking about?
Jeremiah is offline
post #5 of 5 (permalink) Old Feb 4th, 10, 07:02 PM Thread Starter
Dee
That's exactly what I'm talking about!
Wow, the intake looks kinda tall for a stock cowl. What part of OK are you in? I'd like to see some of these.
