Help - Team Camaro Tech
post #1 of 10 (permalink) Old Feb 4th, 10, 04:29 PM Thread Starter
Help
first off let me say hello, I registered here by following this thread https://www.camaros.net/forums/archiv.../t-110978.html
And I want to say thank you in advance,
I have a truck.. Sorry not a Camaro
It is a 1993 Z71 with a GM crate engine 385 Fast Burn, with a Holley High Rise intake and a 4bbl TB..
It has (if you read that thread) a Holley commander 950 !!, At this point I am thinking of throwing a carb on it and calling it quits ! I live in a colder climate (Great White North) in the last month the truck has been on the Hook twice I think it would prefer to be in FLA or Mexico in the sand lol
3 sets of plugs
3 oil changes
Coolant temp sensor
Labor
=$800
I just havent the time nor the spot to work on it during the winter, I know I fail as a car guy, trust me I would prefer to fix it myself.. but the cold temps keep me from that.
the last person to tune the truck has my data cable and DISKS.. he has vanished from the face of the earth and the shop he was working at says it is not there issue.
I have a data cable but can not lean down the fuel with out the software, Right now after dropping 800 in to the truck just can't drop the 100 or so on new disks..
I called the guy in that thread and left a msg, But I am wondering if someone could be kind enough to upload the software, As I just set up my laptop for XP to be able to turn the fuel down a little right now its a A/F of 5% and well thats an issue when it is cold lol..
Again if you have it or know where I can get it it would be muchly appreciated!
I had to take my car out of storage Please Help
Monster385 is offline
post #2 of 10 (permalink) Old Feb 4th, 10, 05:18 PM
Jody
camcojb's Avatar
Re: Help
3 sets of plugs
3 oil changes
Coolant temp sensor
Labor
=$800
you can download the software off the Holley site...............
http://www.holley.com/data/TechServi...950c_v3_07.exe
Jody
camcojb is offline
post #3 of 10 (permalink) Old Feb 4th, 10, 05:23 PM
Vintage 68's Avatar
Wink Re: Help
See if you can't get one of the Mods to move your thread over to the EFI forum - https://www.camaros.net/forums/forumdisplay.php?f=70
Bet you'd get more help there.
(click on the little whistle icon in the upper-right corner of your thread to report and ask to move)
You might also want to post a thread on the HAMB board.
http://www.jalopyjournal.com/forum/index.php
Lot's of guys over there use the Holley system.
I don't have that software or would forward a copy to you.
Sort-of a Delphi guy
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 10 (permalink) Old Feb 4th, 10, 06:43 PM Thread Starter
Re: Help
Jody
thats not the full program
post #5 of 10 (permalink) Old Feb 4th, 10, 06:43 PM Thread Starter
Re: Help
thanks
post #6 of 10 (permalink) Old Feb 4th, 10, 07:10 PM
Jody
camcojb's Avatar
Re: Help
I downloaded it before and it was everything I needed to tune a friends car. Not sure if that is the same download though..........
Go here and contact Doug F. He's the moderator of the efi section and is a Holley EFI engineer, I'm sure he can provide the link you need.
http://www.chevytalk.org/fusionbb/sh...uel_Injection/
Jody
camcojb is offline
post #7 of 10 (permalink) Old Feb 5th, 10, 07:07 AM
Jody
camcojb's Avatar
Re: Help
by the way, I downloaded it just now, sure looks like everything you'll need software-wise to hook up and tune your car........................... Create a new folder to extract it to, not your desktop........... After extracting it hit setup and it installs the tuning software to your computer. Hook up your cables to the computer and ecm and have at it.
Jody
camcojb is offline
post #8 of 10 (permalink) Old Feb 5th, 10, 07:45 AM Thread Starter
Re: Help
Jody
Thanks Jody, I must need some updates as it wouldn't install, will check it out when I get home. I wonder if maybe because I am running it on a Virtual Machine inside Windows 7 it could be creating issues.. will look into it more when I get back to the house, Again thank you.
Will be nice to change the Air Fuel ratio thats at like 5 LOL
Won't be a proper tune until I get into it and figure out what the injector psi is as Holley doesn't have a base map for the 385!
what I know of this motor is,
385 fast burn with a GM hot cam Holley high rise intake and a 4bbl TB, edlebrock headers its not a tuned port but is injected.
post #9 of 10 (permalink) Old Feb 8th, 10, 08:42 AM Thread Starter
Re: Help
Update
Ok this is where I am at, I finally got the Holley 950 software to run now awaiting new Data cable,
Problem
The Commander 950 is supposed to delete the Stock ecu is it not ?
If so Who ever hooked this up has it piggy backing, Truck runs with out the Stock ECU, but not solely on the Stock ECU.
Once stock ecu is removed truck loses about 100 HP and Shift Points.
So I got to thinking, Install One of the 2 SuperChips I have, One is Mild the other Wild.. Just my luck I put in the Wild one haha talk about a Brand new truck.
Once I receive the data cable 2 or 3 days I will remove yet again the stock ECU and go from there ?
post #10 of 10 (permalink) Old Feb 15th, 10, 05:13 PM Thread Starter
Re: Help
ok got a data cable... What steps should i take to lean out the fuel.. Right now I am Air/fuel 11.0 to A/F 11.5 WOT ??
The truck is still flooding itself out on idle and takes a minute of driving to clear itself up
