tank conversion - Team Camaro Tech
 1Likes
post #1 of 17 (permalink) Old Feb 27th, 10, 06:09 PM Thread Starter
ray
tank conversion
can someone supply me with instructions and a parts list to convert a stock fuel tank for a 69 camaro, i,am planning on purchasing a fast ez efi master carb to efi kit. that has a external fuel pump. thank you ray.
rayscool69 is offline
post #2 of 17 (permalink) Old Feb 28th, 10, 02:17 AM
re: tank conversion
Ray, you should take your address out of the location. It more of a general question and displays on the right hand edge of the screen.
Anyways, there are a couple different options for what you need to do.
You can get a weld in sump to modify your current tank to work, check summit racing.
Or you can get a whole new tank from numerous sources.
400bird is offline
post #3 of 17 (permalink) Old Mar 1st, 10, 10:43 AM
re: tank conversion
even if you run an external tank you need to baffle your pickup in the tank. There are several vendors that offer a bolt-in baffled tank with intank pump and return line that will fill your needs nicely and protect you from fuel starvation, for under 500 bucks.
67 Camaro LS1+ tvs2300/4L70E 530 RWHP
64 Corvette Coupe 350/ TKO600
66 Mustang (289/C4)
c6matt is offline
post #4 of 17 (permalink) Old Mar 2nd, 10, 08:49 PM
Bob
MileHigh69's Avatar
re: tank conversion
Tanks Inc. has an in tank pump. You will need to cut a hole in your tank.
_______________________________
69 Camaro, Air Ride Suspension,
Procharged HO 454, 700R4, 12 bolt with Yukon axles, 3:73 gears posi, Pypes 2.5" X pipe with Borla XS mufflers. Retrotek Speed EFI, Ridetech suspension.
Rushforth rated X with Toyo tires. MSD 6 ignition.
Wilwood 6 piston Dynalite disc brakes with Hydratech booster.
MileHigh69 is offline
post #5 of 17 (permalink) Old Mar 2nd, 10, 11:13 PM
Steiner
re: tank conversion
All you really need is a piece of 3/8" hard line and some JB-Weld. Use a piece of coat hanger and bend it like your existing sending unit line to where it connects to the hard line on the frame rail. Use that to bend the 3/8" hard line to shape with a couple of inches on the end to stick down in the sending unit plate.
Cut off your existing sending unit line leaving the portion that extends to the back edge of the tank. Drill a hole in the sending unit and JB-Weld in the 3/8" line you bent. Connect that to the hard line on your frame rail and it will now be your return line.
Use a double flare tool and only the first step of a double flare to make a bulge or barb on the end of each line where you are going to connect fuel hose.
Connect to the cut off end of your original sending unit line and run to your pump which should be mounted close to the tank and as low as practical. Run flex line from the pump to the regulator and throttle body. The Summit Racing braided flex is 100% synthetic nitrile lined and rated for 1000psi.
Conversely, I guess you could cut the sending unit line like above and cut the hard line off before it travels up the frame rail and use the hard line as your feed line but you would need the correct high pressure fittings. Then you could mount the regulator on the frame and run the return directly back to the tank while having just the feed going to the engine compartment.
I do not have the starvation issues some have reported while using the aftermarket tanks.
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 17 (permalink) Old Mar 8th, 10, 09:15 PM
Reade
re: tank conversion
summit racing also has sending units allready with a return line on it aswell. i just got mine.drop the tank swap it out.
run regular fuel line or hose to the pump as low as you can as steiner said. add high pressue line from the output side of the pump. i used the factory line as the return and braided with -6an fittings for output.
im in the middle of doing this all now and it seams to be working sofar ill keep you guys up to date if any probs and open to sugestions.
Rg68lt16spd is offline
post #7 of 17 (permalink) Old Mar 13th, 10, 05:43 PM
Bill
re: tank conversion
Or you could just buy this
http://www.robbmcperformance.com/pro...78_gmsend.html
Just 1 More likes this.
BEECHFRONT is offline
post #8 of 17 (permalink) Old Mar 16th, 10, 05:14 PM
Fred
re: tank conversion
Don't listen to Steiner! He's a perfectionist.
Do it like this,,,,sorta. The return line is now the original feed line at the top of the tank because the regulator is now on the engine. Oops, didn't Steiner do it that way?
128.79mph 1.428 60'
Fred Ficarra is offline
post #9 of 17 (permalink) Old Mar 16th, 10, 05:18 PM
Steiner
re: tank conversion
I think I detect a note of sarcasm there.
'69 Camaro
500hp/538lbft
Steiner is offline
post #10 of 17 (permalink) Old Mar 16th, 10, 05:38 PM
Fred
re: tank conversion
A loving one
128.79mph 1.428 60'
post #11 of 17 (permalink) Old Mar 16th, 10, 05:44 PM
Steiner
re: tank conversion
A loving one
I'm spoken for.
'69 Camaro
500hp/538lbft
Steiner is offline
post #12 of 17 (permalink) Old Mar 17th, 10, 11:28 AM
Fred
re: tank conversion
I'm spoken for.
Me too. Besides, you're not my type.
128.79mph 1.428 60'
post #13 of 17 (permalink) Old Mar 18th, 10, 10:51 PM
David Pozzi
davidpozzi's Avatar
re: tank conversion
I just installed an EzEfi on a 68 Camaro. Didn't do any mods to the tank and it's working ok so far. I haven't autocrossed the car but in simple driving around I got to 1/8th tank and it didn't stall or anything. I'm not saying a sump isn't a good idea, but I think the throttle body type system is a little more forgiving than some of the others.
I attached a plate to the fuel tank straps and mounted the pump to that, used the stock pickup as feed to the pump and drilled a hole in the front center of the tank and installed a bulkhead fitting for the return, dash 6 AN.
davidpozzi is offline
post #14 of 17 (permalink) Old Mar 19th, 10, 09:19 AM
re: tank conversion
Do you have any pictures of the tank setup? I am in the process of installing a powerjection on my bbc 1968 camaro and am just starting this. Thanks John
1968 396 SS Red/Red Deluxe interior.
Been updated to a 460ci
Powerjection 1
700r4
oirginal 12 Bolt.
1968 Camaro is offline
post #15 of 17 (permalink) Old Mar 19th, 10, 10:48 AM
Fred
re: tank conversion
I'd planed to use screws to hold the plate seen in post #8 to the tank straps. Then I lined up the plate. Wow. All I had to do was make a slight cut in the sheet metal at the bottom of the retaining straps so the sheet metal would follow the curve of the tank. Then loosen the straps, tuck the mount under them and tighten. Two bolts at the top are the only fasteners needed. The center flange of the gas tank holds the plate away so that the pump vibration mount studs never touch the tank. Here's look again so you don't have to scroll.
128.79mph 1.428 60'
