custom fuel injection tank - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 20th, 10, 07:43 PM Thread Starter
george
Just completed my custom tank. Seems to working ok. Nice and quiet pump. The pump I used is for a '99 Ford F-350 truck. Made a drop shelf for the clearance issue between tank and trunk floor.
firstgenguy is offline
post #2 of 5 (permalink) Old Apr 21st, 10, 03:31 PM
Carl
Re: custom fuel injection tank
What's your required pressure at the fuel rail?
CarlC is offline
post #3 of 5 (permalink) Old Apr 21st, 10, 07:45 PM Thread Starter
george
45 psi
post #4 of 5 (permalink) Old Apr 21st, 10, 10:53 PM
Carl
That will work. That pump is ineffective for later model 58psi requirements.
Nice work on the tray. Did you weld, solder, or braze it to the tank?
CarlC is offline
post #5 of 5 (permalink) Old Apr 22nd, 10, 04:28 PM Thread Starter
george
I used a mig welder to attach it to the tank then ground down the weld. After that I soldered the seams and around the bolts for any pinholes.
Using it for my small block with a TPI setup. Hopefully the moudule will eliminate the fuel starvation problems around corners I had.
