who's using spectre EFI tank - Team Camaro Tech
post #1 of 9 (permalink) Old Jun 5th, 10, 06:42 PM Thread Starter
Maurice
Im interested in hearing from any of you guys using the spectre EFI fuel tank. what engine you are running with it and if your using the stock pump that came in the tank. If not, what pump have you upgraded to for your particular application.and what EFI system your using with this tank set up.
I have this tank for my ZZ 502 MPFI application, in it's stock configuration. Im trying to get a concensus of what the HP limitations the stock pump are.
Thanks !
68zz502fi is offline
post #2 of 9 (permalink) Old Jun 5th, 10, 08:03 PM
Re: who's using spectre EFI tank
I'm running stock LS1 with mine, and the pump that came with the tank. Fuel gauge will read no higher that just above 1/2 tank at fillup. After about 75 miles its starts to come down & seems to be accurate. At 1/4 tank or less, any quick turn, even at low speed, will starve for fuel and stall. It will re-start once the fuel settles. I just am getting used to filling up around 1/4 tank. Pump is quiet. What are the fuel requirements for the 502? I'm not really familiar with the FI on your setup. I read the spectre tank will support around 450 hp. Performance seems good as long as you keep it full. Scott
69 RS LS3/T56
68 Firebird vert LS1/4L60E
67 RS LS2/T56
Z06vette is offline
post #3 of 9 (permalink) Old Jun 5th, 10, 08:45 PM Thread Starter
Maurice
thanks Scott,
the ZZ502 is supposed to be 502 HP. I talked to an enging builded and he's dyno'd a few of these. he said their pretty close to the 502 HP mark.
he said some may dyno as high as 515-520, from his experience.
so I'd say around those numbers for fuel requirments.the 450 HP on the stock pump is a bit low for my application and will likely require an upgrade.
I wonder if theres anybody out there pushing the stock pump in the spectre tank to 500 HP or so ?
hopefully more people will post regarding this...
Thanks !
post #4 of 9 (permalink) Old Jun 9th, 10, 06:38 AM
Frank
We just used one one a 500HP LS3 and the fuel pump died in 2 hours. So we are upgrading the pump to a Walbro
ProdigyCustoms is offline
post #5 of 9 (permalink) Old Jun 9th, 10, 12:47 PM Thread Starter
Maurice
frank,
I'd be very interest in what Walbro pump you end up using in the spectre tank. I'd guess a 255 LPH
thanks
post #6 of 9 (permalink) Old Jun 9th, 10, 08:32 PM
Frank
Got to try and fit it in there. Stay tuned.
post #7 of 9 (permalink) Old Jun 25th, 10, 12:27 PM Thread Starter
Maurice
Any news on what pump you put in the spectre tank ?
BE different....ACT normal.
No one is completely useless..They can always be used as a bad example
post #8 of 9 (permalink) Old Jul 12th, 10, 07:48 PM
Rick
Camaro67_rcl's Avatar
Send a message via Yahoo to Camaro67_rcl
bump
Rick
67 RS/SS 355, Autogear M21 (w/Overdrive), 8.5w/3.42
Camaro67_rcl is offline
post #9 of 9 (permalink) Old Jul 23rd, 10, 06:05 AM
Bob
MileHigh69's Avatar
I use a Walbro in tank . It is a 255 LPH. I have about 600 HP with a Procharger. No problems feeding it. I used a stock tank with a Tanks Inc drop in. It has a tray at the bottom. I use the stock sending unit. I am changing to a Spectre tank and am going to weld in a depression for the Tanks inc unit. I am also considering one of these.
http://www.rickscamaros.com/camaro-g...rted-1969.html
_______________________________
69 Camaro, Air Ride Suspension,
Procharged HO 454, 700R4, 12 bolt with Yukon axles, 3:73 gears posi, Pypes 2.5" X pipe with Borla XS mufflers. Retrotek Speed EFI, Ridetech suspension.
Rushforth rated X with Toyo tires. MSD 6 ignition.
Wilwood 6 piston Dynalite disc brakes with Hydratech booster.
MileHigh69 is offline
