routing fuel lines with SFC - Team Camaro Tech
post #1 of 1 (permalink) Old Jun 13th, 10, 08:05 PM Thread Starter
I am finally ready to run fuel lines and was going to just purchase pre-bent ones from Rightstuff but paused.....I know the original ones follow the subframe on the outside and then cut across to the inner aspect of the frame rails and back the rest of the way. The DSE subframe connector is welded where the line just cut over.
If someone has run pre bent lines with the DSE SFCs let me know if it is a go to order them or not a good idea.
PS I was planning on getting 1/2" SS lines but if much bending and tweaking is needed maybe should go aluminum.
68 coupe ,572,tko
Denvervet is offline
