Gen 1 Vs LS Aluminium engine - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 17th, 10, 07:51 AM Thread Starter
Rico
Assume LS alum motor LS2 or 3... Assume SBC Dart SHP block steel crank and Alum heads...
What is the weight savings for the LS?
XLexusTech is offline
post #2 of 3 (permalink) Old Jun 21st, 10, 06:21 PM
Chris
Re: Gen 1 Vs LS Aluminium engine
Well I can tell you this much.. the weight difference between an aluminum Ls2 and iron Ls2 block is 80lbs.. If that helps
1969 Camaro Prostreet 406ci (Jensen engine)
1998 Camaro Z28 M6 370ci Lq4
nhra_crazy is offline
post #3 of 3 (permalink) Old Jun 28th, 10, 08:58 PM
Dan
I think the gen-1 is just a bit lighter, the listed weight on my 427 is suppose to be 355 pounds, I recall ls alum motors at 450, but I don't know if the LS # is with the water pump, alternator, etc. Are you getting bad ideas? -Dan
62 Corvette (Stock Restoration)
68 RS/SS Camaro, LS7/T56
68 RS Convertible project LS3/480/4L70
2006 Corvette Z06
2011 Corvette GS Convertible
68sixspeed is offline
