Goodyear .375 fuel hose - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 20th, 10, 11:41 AM Thread Starter
I purchased a 25' roll of Goodyear fuel hose for my EZ-EFI conversion and painted on the hose is 50 psi, but on the label on top of the spool there is a warning not to use on pressure lines for fuel injected engines. Since the working pressure for this system is 43 psi, does this warning not apply to my specific application?
DEZDEZ is offline
post #2 of 4 (permalink) Old Jul 20th, 10, 01:26 PM
Vintage 68's Avatar
Wink Re: Goodyear .375 fuel hose
In general, the working pressure of a hose should be no more than 25% of the rated pressure or @ 4:1 safety factor for most applications.
This is specially important for automotive applications - because of the excessive heat under the hood areas.
So that hose would have a working PSI of @12~13psi if it was used accourding to accepted standards.
I would purchase hose specifically designed for the higher Fuel Injection system pressures.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 4 (permalink) Old Jul 20th, 10, 01:53 PM Thread Starter
Thank you, your explanation will lead me to return this hose and get the specific F.I. hose. Much appreciated.
DEZDEZ is offline
post #4 of 4 (permalink) Old Jul 20th, 10, 08:18 PM
Steiner
Remember, the 43 pounds is AFTER the regulator so you're getting higher pressure supplied to it. Get the Aeroquip teflon lined hose that Summit carries. Practically everything else leeches fuel smell through the hose.
'69 Camaro
500hp/538lbft
Steiner is offline
