Holley Avenger MPFI installed and running! - Team Camaro Tech
post #1 of 14 (permalink) Old Aug 2nd, 10, 05:51 PM Thread Starter
Vince
For those who are interested in this sort of thing:
http://www.chevelles.com/forums/showthread.php?t=326671
VINCE
69 CHEVELLE SS
502 EFI/[224/228 HR]/T56/3.90
*1.8/11.59/124.34*
SIDEWAYS is offline
post #2 of 14 (permalink) Old Aug 3rd, 10, 07:46 PM
Big Dave
Re: Holley Avenger MPFI installed and running!
That looks great!
Keep us informed as to the progress!
And pics too.
'69 camaro, was orig SS 396 car.
original tranny & 12 bolt
Now:
568 ci, Merlin Pro block
Callies crank, Oliver rods
AFR CNC 325, Nash 5 speed, 9'' Ford 35 spline locker
F1 Procharger that will get on soon...
69 merlinpro565 is offline
post #3 of 14 (permalink) Old Aug 4th, 10, 12:17 AM
Steiner
Sweeeeet. Hey, if you're still having air cleaner problems you might consider the shorter K&N on your drop base along with one of their Xtreme lids which adds an additional 500cfm flow capacity. I used to run one with a flat base since the drop base hit the HEI. Finally got the drop base and 3" filter to work with a small spacer.
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 14 (permalink) Old Aug 4th, 10, 04:16 AM Thread Starter
Vince
Problem with the shorter filter is that the air cleaner base is already too close to the lid itself for my liking, any shorter of a filter will just bring the two even closer to each other. But so far, all is well and she runs INCREDIBLE!!!
VINCE
69 CHEVELLE SS
*1.8/11.59/124.34*
SIDEWAYS is offline
post #5 of 14 (permalink) Old Aug 4th, 10, 05:03 PM Thread Starter
Vince
VINCE
69 CHEVELLE SS
*1.8/11.59/124.34*
SIDEWAYS is offline
post #6 of 14 (permalink) Old Aug 5th, 10, 10:19 AM
Chuck
Originally Posted by SIDEWAYS View Post
Great video. I have the HP system on order, but can you use one of these with the system, or just the small cap one. Thanks
chuck0379 is offline
post #7 of 14 (permalink) Old Aug 5th, 10, 12:07 PM Thread Starter
Vince
Looking at my MPFI setup, I'm not sure sure that the large cap HEI would fit between the fuel rails. It may, but will be real close.
VINCE
69 CHEVELLE SS
*1.8/11.59/124.34*
SIDEWAYS is offline
post #8 of 14 (permalink) Old Aug 6th, 10, 04:45 AM
Chuck
Thanks. Hopefully mine will arrive soon it been three weeks so far and no efi....
post #9 of 14 (permalink) Old Aug 6th, 10, 05:23 AM Thread Starter
Vince
Which system did you go with Chuck?
VINCE
69 CHEVELLE SS
*1.8/11.59/124.34*
SIDEWAYS is offline
post #10 of 14 (permalink) Old Aug 6th, 10, 10:46 AM
Chuck
Holley HP MPFI 550-835 with 48lb injectors and the 5.7 Touch Screen. Nice vids by the way. I hope they are that easy to set up.
post #11 of 14 (permalink) Old Aug 6th, 10, 12:30 PM Thread Starter
Vince
You will be very happy. My runs so good I dont know what to do with myself. I almost feel a little guilty, cause I havent had any issues at all. Set up in a minute, and was driving. And it drove WELL...no hiccups, burps, farts...just smooth power - and alot of it!
Good luck with yours and keep us posted.
VINCE
69 CHEVELLE SS
*1.8/11.59/124.34*
SIDEWAYS is offline
post #12 of 14 (permalink) Old Aug 10th, 10, 08:54 AM
Chuck
Vince,
Just got mine in the mail today but I don't see a wire to connect the harness to the Distributor. Is it supposed to be the hei adapter wire? Do you have a pic of how yours connects to the Distributor? The large cap fits, but as you said it is close. Probably going to return it and go with a small cap MSD 8366 as the instructions recommend. Thanks.
post #13 of 14 (permalink) Old Aug 10th, 10, 09:56 AM Thread Starter
Vince
Vince,
http://www.holley.com/558-304.asp
This is what I have, cant remember if it came with my kit or if it was ordered separately. Keep in mind, this is for a small-cap HEI with the external coil...I dont think this will fit the large cap HEI's. My distrib/coil came from a salvage yard off of a mid 90's V8 GM truck. Nothing special, 50.00 for the distrib and coil to my home. Just spent an hour taking it apart and making sure it was clean inside and out. You can get a new one from Advance/Autozone, etc.
VINCE
69 CHEVELLE SS
*1.8/11.59/124.34*
SIDEWAYS is offline
post #14 of 14 (permalink) Old Aug 10th, 10, 12:39 PM
Chuck
Thanks, new coil, and HEI on order.
