New Holley HP EFI Pics 550-835 BB/Oval Port - Team Camaro Tech
post #1 of 44 (permalink) Old Aug 11th, 10, 03:44 AM Thread Starter
Chuck
Just received the package from Holley yesterday and thought I would share some pics.
chuck0379 is offline
post #2 of 44 (permalink) Old Aug 11th, 10, 06:41 AM
Jess
Re: New Holley HP EFI Pics 550-835 BB/Oval Port
Im digging it...
Jess67
67 Camaro Blue 427, 4-speed, 12 bolt
67 Camaro 350, 200-4R, PS, AC, PB, IN PARTS
Jess67 is offline
post #3 of 44 (permalink) Old Aug 11th, 10, 07:54 AM
Dan
trackman's Avatar
The intake is a very nice piece. I chose the edelbrock for my hp set up. It is a little shorter and might have a chance to fit under the hood. It won't look that nice.
The throttle body looks all business.
Are you replacing a carb or is this a new build?
67 RS convertible
Mark Jones 496...690hp
Liberty modified TKO600
Holley HP EFI
trackman is offline
post #4 of 44 (permalink) Old Aug 11th, 10, 08:00 AM
Lex
Lexlas's Avatar
Wow !!
68 Camaro / 400 ci / 3.73 10 /
Edelbrock Performer Series 600 cfm no. 14054
Edelbrock Performer EPS Intake Manifold 27014
98 GMC Suburban / 454 V8 / K2500 4x4
Lexlas is offline
post #5 of 44 (permalink) Old Aug 11th, 10, 08:05 AM
Jason
now that is cool!!
1967 Camaro Yenko Pro Touring Tribute (being built)
Follow my build
67YenkoJC is offline
post #6 of 44 (permalink) Old Aug 11th, 10, 11:25 AM Thread Starter
Chuck
I ordered the Vic Jr EFI intake, and didn't like as much as the holley intake, so I returned it to Summit. It was about 1 inch shorter though.
This will be going on my new 496 with AFR's 290 heads.
post #7 of 44 (permalink) Old Aug 11th, 10, 05:50 PM
Vince
Looks nice Chuck. Now, do you happen to have a set of oval gaskets laying around? I'm curious to see if the ports on that intake are large enough for a good port match to the heads. Holley EFI oval intakes in the past fit the peanut heads. If this is still the case, you need to open those things up big time.
VINCE
69 CHEVELLE SS
502 EFI/[224/228 HR]/T56/3.90
*1.8/11.59/124.34*
SIDEWAYS is offline
post #8 of 44 (permalink) Old Aug 12th, 10, 05:12 AM Thread Starter
Chuck
Hey are the pics. Do you think it would be worth the effort to have the port matched? It is a 4 hour drive to the machine shop, and the price isn't cheap here in the UK with the dollar to pound conversion. Probably about $800 total to have them ported to include gas there and back. I am willing to do it though. The Vic Jr had the same size ports as well.
post #9 of 44 (permalink) Old Aug 12th, 10, 05:56 AM
Vince
Damn - worse than I thought. Yes, you need to have them opened-up mucho! I know its a pain, but man, those ports are tiny on that intake.
It almost looks like you would be better off using the rectangular intake, and save yourself the port job????
So the Victor's ports were that small too huh?
You should send this photo to Tony Mamo, see what his thoughts are. I'll give him this link.
VINCE
69 CHEVELLE SS
*1.8/11.59/124.34*
SIDEWAYS is offline
post #10 of 44 (permalink) Old Aug 12th, 10, 08:46 AM Thread Starter
Chuck
I've got a Vic Jr intake in the Garage I can post pics of if you want. It's not the EFI one, but they should be the same. It is a pretty big difference when you see the pic, but just looking at them they don't look as bad. I should get the block from the machine shop tomorrow and then make the journey next week to have it ported. The machine shop wants a bare block, head gaskets, and the heads... should be fun.
post #11 of 44 (permalink) Old Aug 12th, 10, 09:43 AM
Vince
I had a Victor rec port, and the ports were a pretty good fit to my AFR rec port heads. I cant imagine the Victor oval port would use peanut-types ports like this Holley does. Either way, probably be better off just having this ported so you dont have to change everything over to run the Vic.
There was a thread somewhere where a fellow was running that Holley intake, and his car mysteriously wasnt running as fas as he thought. Had that intake ported, and the car picked-up big time. Will post it if I can fold it.
VINCE
69 CHEVELLE SS
*1.8/11.59/124.34*
SIDEWAYS is offline
post #12 of 44 (permalink) Old Aug 12th, 10, 10:00 AM
Vince
here you go Chuck:
http://www.horsepowerracing.com/html/holley_mpfi.html
VINCE
69 CHEVELLE SS
*1.8/11.59/124.34*
SIDEWAYS is offline
post #13 of 44 (permalink) Old Aug 12th, 10, 10:15 AM Thread Starter
Chuck
Thanks. I will get it ported.
post #14 of 44 (permalink) Old Aug 13th, 10, 03:44 AM Thread Starter
Chuck
Hey Vince what Tach are you running with your small cap HEI OEM or aftermarket? If you have an OEM tach did you have any issues with it?
post #15 of 44 (permalink) Old Aug 13th, 10, 04:20 AM
Vince
Running the factory tach and a colum mounted tach (easier to see). No issues whatsoever. Not to mention the tach feature in this little handheld. Yes - 3 tachs!!!
The coil that I got from the salvage yard had a wire coming off of it for a tach connection, couldnt of been easier to hook up.
VINCE
69 CHEVELLE SS
*1.8/11.59/124.34*
SIDEWAYS is offline
