TBI for a blow through application? - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 11th, 10, 10:46 PM Thread Starter
Paul
MCGOO's Avatar
Question TBI for a blow through application?
I have seen a lot of throttle body injection units on the market, but was wondering if any of them can support a turbo blow through application?
I think a TBI would be more reliable and tuneable than a carb, but probably not as good as a port injected system.
Anyone have some info on this idea?
Paul
'69 Camaro, 250 inline 6, EFI Turbo rebuild is running!!
, CC5S TKO 500, and more.
V8 Camaros are like navels......Everybody has one.
The Toad. 1970 base Camaro (Navel), 350, turbo 700R4, 3.73 posi, Hotchkis TVS system,
Mrs. McGoo's & McGoo Jr.'s toy
MCGOO is offline
post #2 of 6 (permalink) Old Aug 11th, 10, 10:58 PM
Steiner
Re: TBI for a blow through application?
The Retrotek can. Call and ask for Cody. He's got a blow through Vortech on the Powerjection III in his '72 El Camino. Got the supercharger free too, the a-hole.
Just call 323-599-5032 and ask for Cody at extension 1404.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 6 (permalink) Old Aug 13th, 10, 08:34 PM
Bob
MileHigh69's Avatar
I have a retrotek with a procharger D1SC. Works nice now. Very easy to work with.
_______________________________
69 Camaro, Air Ride Suspension,
Procharged HO 454, 700R4, 12 bolt with Yukon axles, 3:73 gears posi, Pypes 2.5" X pipe with Borla XS mufflers. Retrotek Speed EFI, Ridetech suspension.
Rushforth rated X with Toyo tires. MSD 6 ignition.
Wilwood 6 piston Dynalite disc brakes with Hydratech booster.
MileHigh69 is offline
post #4 of 6 (permalink) Old Aug 14th, 10, 05:57 PM Thread Starter
Paul
MCGOO's Avatar
Thanx guys, I am going to look into this. Port injection is a consideration for my project, but there seems to be some complicated issues at higher boost levels. TBI would make it easier.
Paul
MCGOO is offline
post #5 of 6 (permalink) Old Aug 14th, 10, 10:45 PM
Jody
camcojb's Avatar
Paul
you have way more room for growth with a MPI system vs a TBI. TBI is fine, but you will be power limited due to only 4 injectors and the sizes available. For a mild to medium powered setup it'd work great, but won't work on a max effort build as you can't get enough fuel into the motor.
Jody
camcojb is offline
post #6 of 6 (permalink) Old Aug 15th, 10, 10:07 AM Thread Starter
Paul
MCGOO's Avatar
Thnax Jody,
I know there is more room for improvement with the MPI, and I have not ruled it out yet. I was just wondering what is available in TBI knowing that there has been a lot of progress made in the whole EFI world.
My little 250 may not need more than a good TBI unit can provide. I am at the bottom of a very steep leaning curve with turbos and EFI so I just want to make sure I don't overlook anything. That is also why I frequent many forums on these topics and toss out a few questions once in a while.
Originally the projest was going to be in and running for September, but I am looking at May now.
Paul
MCGOO is offline
