Sending Unit - Team Camaro Tech
post #1 of 11 (permalink) Old Dec 6th, 10, 05:53 PM Thread Starter
foreverlookin's Avatar
Sending Unit
I am thinking of either easi-efi or powerjection TBI. I would have to run a return back to the tank and presently don't have a return port on the sending unit. Should I consider changing the sending unit with one with a return?
foreverlookin is offline
post #2 of 11 (permalink) Old Dec 6th, 10, 06:29 PM
Re: Sending Unit
This Moroso kit would work good.
http://www.moroso.com/catalog/catego...?CatCode=32029
post #3 of 11 (permalink) Old Dec 7th, 10, 08:13 PM
scblucam's Avatar
Re: Sending Unit
What about venting the tank? Thar looks more like a vent than a return.
68 302 M20 - 85 IROC Z
scblucam is offline
post #4 of 11 (permalink) Old Dec 8th, 10, 03:15 AM
Re: Sending Unit
Gas cap is the vent.
post #5 of 11 (permalink) Old Dec 8th, 10, 07:11 PM
scblucam's Avatar
Re: Sending Unit
There are several other threads on here that state otherwise. I have been struggling with the same issues before pulling the trigger on EFI. In tank pumps, in line pumps, baffled or non baffled tanks. If the gas cap is a viable vent, thats great, but I dont want a gas line in my trunk. AAARG
scblucam is offline
post #6 of 11 (permalink) Old Dec 9th, 10, 03:15 AM
Re: Sending Unit
I wouldn't want a gas line in the trunk either. The Moroso kit allows a return to be placed in the fill tube under the floor as in behind the license plate holder.
Since the early gas caps vent in one direction, a mid-'70's cap may have to be used to vent both ways or, if the return line is used, a pressure relief valve plumbed in to relieve the tank, say 2 PSI.
post #7 of 11 (permalink) Old Dec 9th, 10, 11:50 AM
David Pozzi
davidpozzi's Avatar
Re: Sending Unit
Stock Camaro caps vent in and out, but hold back a fraction of a psi to prevent gas fumes from escaping.
davidpozzi is offline
post #8 of 11 (permalink) Old Dec 9th, 10, 06:14 PM
scblucam's Avatar
Re: Sending Unit
Yes I forgot the connector was below the floor. It has been a while since it was apart. circa 1986
scblucam is offline
post #9 of 11 (permalink) Old Dec 10th, 10, 06:09 AM
Re: Sending Unit
David how has your efi fuel tank setup been working in low fuel situations now that you've had more run time? Do you notice any pressure when removing the cap after a long drive? My stock 69 does that some times?
Dave69Z is offline
post #10 of 11 (permalink) Old Dec 22nd, 10, 05:42 PM
Joe
Re: Sending Unit
Hey Guys I am wanting the same as Steve, EFI in my 68 Camaro, I am looking at the Holley and FAST EZEFI, with a similar question, will a 69 sending unit work in my 68? That would give the return line, or I was told about the 3rd gen sending unit with internal fuel pump? From my reading the internal would be a better option. Any thoughts or options you would suggest? Thanks Joe
68, 396- 330 RWHP/ 354lbsTQ. TKO 600- 5 Speed. Ford 9in- 3.70 gear. Magnaflow 2 1/2 inch exhaust. --Semper Fi-Joe
Dirt's68 Camaro is offline
post #11 of 11 (permalink) Old Dec 31st, 10, 02:52 PM
Bob
MileHigh69's Avatar
Re: Sending Unit
Go to ROBMC performance and look at his sending units. They fit in the standard 69 sending connection. This will work with an external pump. If you want to use an internal use a IN Tank unit from Tanks.
http://www.robbmcperformance.com/
_______________________________
69 Camaro, Air Ride Suspension,
Procharged HO 454, 700R4, 12 bolt with Yukon axles, 3:73 gears posi, Pypes 2.5" X pipe with Borla XS mufflers. Retrotek Speed EFI, Ridetech suspension.
Rushforth rated X with Toyo tires. MSD 6 ignition.
Wilwood 6 piston Dynalite disc brakes with Hydratech booster.
MileHigh69 is offline
