LS swap with factory A/C box - Is it possible? - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 14th, 10, 12:45 PM Thread Starter
Pete
I have a 68 327 with factory AC which I'd like to keep. Has anyone done a LS1 (or equivalent) swap and left the factory AC box in place? Is it possible?
Pete
1968 Camaro
2009 Porsche 911 Carrera S
Pete68 is offline
post #2 of 5 (permalink) Old Dec 31st, 10, 03:40 PM Thread Starter
Pete
Re: LS swap with factory A/C box - Is it possible?
Starting to think it cant be done...
Pete
1968 Camaro
Pete68 is offline
post #3 of 5 (permalink) Old Mar 17th, 11, 01:24 AM Thread Starter
Pete
Still no love?
Pete
1968 Camaro
Pete68 is offline
post #4 of 5 (permalink) Old Mar 20th, 11, 09:08 AM
If you are talking about the evap box, It can be modified to allow enough room on right side of engine. I had to cut and remold the box. The motor, headers have plenty of room. Changing the spark plug is a problem. I also have enough room for the water temp sending unit with adapter from S&P. I have not completed the car but I believe it can be done. I used edlebrock mounting plates and headers. Hope this helps.
RILEYZ is offline
post #5 of 5 (permalink) Old Apr 7th, 11, 08:58 AM
Yes, it is possible. I swapped over to a big block "suitcase" and evaporator. Still had to notch and re-glass the LH side of the case to clear. But then I moved my motor back as close to the firewall as I could get it, since I do lots of open track/road course events.
I am 99% sure you would have to cut a BB case anyway though, and am positive you will have to notch a SB case, if it will even fit.
steve da wrench is offline
