5.3 LS truck motor - Team Camaro Tech
post #1 of 16 (permalink) Old Dec 18th, 10, 07:33 AM Thread Starter
Joe
5.3 LS truck motor
I was down at a few local junk yards two weeks ago looking for a small plastic piece for my truck. At every yard I was at, I asked how much for one of the 5.3 motors. My truck is in the 151000+ range now, and I'm not an easy guy on the gas. At every yard I was told $500. This seems like a good price. But my thoughts continued onto my 67 Camaro. Would this make a good conversion motor if I was to put an LS1 intake or a carburated swap intake on? Has anyone already used this motor?
Joe
1967 Camaro - Under Construction
wreckingball is offline
post #2 of 16 (permalink) Old Dec 18th, 10, 08:12 AM
Re: 5.3 LS truck motor
Prices seem pretty good. My buddy has a 57 chevy we are dropping an LQ4 from a Hummer into and he got the engine for like $1500.
You need an ignition controller and to work out the intake issue- carb or FI. I might stash my original 327 and do this one day in my Camaro.
Melrose RS is online now
post #3 of 16 (permalink) Old Dec 18th, 10, 10:13 AM
Seen a few on the LS sites.... not bad price at all but comes down to what it comes with too.
68 Camaro~LSx ~all motor
post #4 of 16 (permalink) Old Dec 18th, 10, 12:52 PM
Chris
thats a good price and most i see at junk yards come with everything from intake and throttle body down to oil pan with all accessories and brackets.If you do get one and are going to rebuild it you can punch the cylinders out to a standard bore 5.7 LS1 and put whatever induction system you want on it,makes a great engine.
CMQuickcoupe is offline
post #5 of 16 (permalink) Old Dec 18th, 10, 09:51 PM
AJ
$500 is okay, I've had numerous friends find them for around $350 complete with harness and all, some of them even with after market cams already installed.
I would highly suggest researching the swap more, and possibly following some LQ builds on LS1 tech to avoid going to a carb. You won't get much better mileage with a carb on an lq/ls vs. a gen I sbc... IMHO if you're gonna do an LS or LQ I'd highly suggest keeping the efi, nothing beats having an engine management system, they are practically indestructible with everything they monitor.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #6 of 16 (permalink) Old Dec 19th, 10, 07:23 AM
SCOTT
I went from a tuned port 305 (dont laugh I didnt put it in there) to an LS1 with a 4L60E. This was not that hard of a swap, as I had just removed an EFI engine. You talk about waking a car up. As aces's 68 said you can beat the managment part of this. You can set all of the engine and trans perameters from your laptop with a tuning program. i am lucky my buddy has the program on his laptop and does all of my tuning for me. He's always wanting me to bring my car over so he can tune on it. he loves that kind of stuff, lemme see if I can get a pic posted for you. I sure enjoy the swap and I think its well worth the money.
before
after
68 RS COUPE LS1
2000 F-350
3 HORSES
OL SCHOOL is offline
post #7 of 16 (permalink) Old Dec 30th, 10, 02:10 PM Thread Starter
Joe
I wonder if the 5.3 intake will fit under a cowl hood, or if putting an ls1 intake on it would be required for it to fit?
post #8 of 16 (permalink) Old Dec 31st, 10, 01:08 PM
Chris
I dont think it will fit its pretty tall compared to an ls1 intake but you can pick them up pretty cheap for a stocker maybe even free lol or 200-300 for an ls6 off corvettes or 2001-2002 camaro or trans am.
post #9 of 16 (permalink) Old Dec 31st, 10, 02:49 PM
Just remember the LS1 intake won't fit with the truck accesories....
69 RS LS3/T56
68 Firebird vert LS1/4L60E
67 RS LS2/T56
Z06vette is offline
post #10 of 16 (permalink) Old Dec 31st, 10, 05:45 PM
Chris
why wont it fit with the truck accessories?
post #11 of 16 (permalink) Old Jan 1st, 11, 08:43 AM
Ryan
Send a message via AIM to rp0029
There is a sticky over in the hybrid section of ls1tech which indicates that you can do the 5.3 l swap for $1500. That section is VERY helpful for this kind of swap. The sticky is called low budget ls swap $1500 or something. Check it out.
Black 1968 Coupe.
Build thread
Modern, fuel injected LS engine DAILY DRIVER!
rp0029 is offline
post #12 of 16 (permalink) Old Jan 1st, 11, 01:14 PM
The truck accessories/brackets are too high to allow the TB to mount on the lS1 intake. The intake fits the motor fine, just need to run different accesories- Fbody/vette, GTO, etc. Check out the link on LS1tech mentioned above. Scott
69 RS LS3/T56
67 RS LS2/T56
Z06vette is offline
post #13 of 16 (permalink) Old Jan 2nd, 11, 11:20 AM Thread Starter
Joe
I just read the thread... Very helpful! Thanks for the help.
post #14 of 16 (permalink) Old Jan 5th, 11, 06:57 AM
the truck acc can work with an ls1 intake, you need to move an idler pully (kitsare availble for around $50) and an 08+ truck waterpump.. did it on my friends 69 gto swap, worked like a champ.. also see my thread on here I documented my ls1 swap, which is essentially the same as a 5.3..
67 Camaro LS1+ tvs2300/4L70E 530 RWHP
64 Corvette Coupe 350/ TKO600
66 Mustang (289/C4)
c6matt is offline
post #15 of 16 (permalink) Old Jan 9th, 11, 07:01 PM
Rex
I bought one...had in punched out to a 5.7 ls1. Installed forged piston and rods, PRC heads ETMC comp cam. Going to install a magnacharger. I'm hoping for 550 to the hoops...the long block..I have 5100.00 in it...I kinda over did the block...should be able to hold 800-1000 horse though..better to have it and not need it, then need it and not have it.
69 x-11..LS1, 420.88 horse to the tires,750 Holley Ultra DP, Torquer V2, darksides headers, PRC heads, 10.8:1 compression, forged bottom end, 5 speed. 2008 King Ranch F150 4x4.
trex70 is offline
Tags
conversion, ls1, motor, restoration, swap
