Rick's EFI Converted Tank for 69 - Team Camaro Tech
post #1 of 2 (permalink) Old Dec 30th, 10, 02:58 PM Thread Starter
While doing a little EFI research the other day, I noticed Rick's First Gen is selling a direct replacement EFI tank with an internal fuel pump. It's pretty pricey. Anyway - is anyone using this setup, or know what brand of fuel pump is supplied with the unit?
69 RS, Hugger orange/black, Deluxe interior, Sony AM/FM/XM/CD, PS & PB. 355, forged pistons, Eagle rods, balanced, Iron Eagles, 9.4:1 CR, .038 quench, XR270HR Cam, Z28 intake, FAST-EZ EFI 2.0, Thorley Tri-Ys, TCI 700R4, 2400 stall, 3.42 posi
LukeWarm is offline
post #2 of 2 (permalink) Old Dec 30th, 10, 04:31 PM
scblucam's Avatar
Re: Rick's EFI Converted Tank for 69
This tank is not that pricey if you consider whT you get. However it is not baffled per their tech line. Hard corners you could lose prime and hence the engine will die. I found a raduator/fuel tan restoration shop in Waller TX that can baffle the tank but need to do a little more research. It would bring the cost of the tank up to close to the Rick's Hot Rod Shop cost.
68 302 M20 - 85 IROC Z
scblucam is offline
