pedal problems - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 22nd, 11, 07:41 PM Thread Starter
pedal problems
Dose anyone have any experence installing/mounting an LS2 throttle by wire pedal. I'm not sure how to mount it so lines up right.
tshirtguyjim is offline
post #2 of 6 (permalink) Old Jan 23rd, 11, 09:07 AM
Jack
Re: pedal problems
No, but a timely question for me. I would like to use your question and add a couple of my own.
I am just starting to collect the installation parts I need for an LS2 into my 67. The gas pedal question I have as well. And...are you using the donor harness or an aftermarket? Another question I have is on the radiator....do I need a cross flow or will the summit direct fit radiator work?
67 RS
Royal Plum/Parchment
6.0 LSX 4L80e
06 corvette Z06
machine silver
jackr is offline
post #3 of 6 (permalink) Old Jan 25th, 11, 08:01 PM
Gene
Re: pedal problems
with respect to the radiator - I plan on using my stock brass 3-row small block radiator. I asked here and on LS1 website and everyone said LS engines have no inherent cooling issues and that radiator should be fine. I am certain that a cross-flow style radiator is not needed.
1969 Camaro - Intense Blue Pearlcoat/white (Baldwin-Motion paint scheme), stock 6.2 liter L92 with VVT, LS3 intake, Doug's Headers; Tremec TKO, 3.73 12-bolt posi.
gheatly is offline
post #4 of 6 (permalink) Old Jan 26th, 11, 01:52 PM Thread Starter
Re: pedal problems
I installed a be cool radiator recomended by summit.
post #5 of 6 (permalink) Old Jan 26th, 11, 01:56 PM Thread Starter
Re: pedal problems
I used a doner harness,and had computer flashed by Wait for me performance.
post #6 of 6 (permalink) Old Jan 30th, 11, 07:53 AM
Jess
Re: pedal problems
Bump for some more input on your pedal question...... I know Ironworks speed & kustom sales a bracket that you can drill to fit your firewall. Other than just mocking it up, not sure what is the best way to locate tho.
NvrDun71 is offline
