Electric fuel pump mounting - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 16th, 11, 07:02 PM Thread Starter
foreverlookin's Avatar
Going to be installing an electric fuel pump and I know it has to be as low to the bottom of the tank and within 2 feet but I would appreciate any pictures people have of theirs as I am going to have to fabricate a bracket to hold it and would like to see an existing one that works.
Thanks!
foreverlookin is offline
post #2 of 8 (permalink) Old Feb 16th, 11, 07:13 PM
Steiner
Re: Electric fuel pump mounting
I made up a nasty bracket out of angle iron and bolted it to the trunk since it was already patched up pretty poorly. Moving the system to another car and am going to try to come up with something a little cleaner.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 8 (permalink) Old Feb 17th, 11, 07:02 AM
Russ
Mine is no where near as fancy as Steiner's. I simply used 2 pieces of flat aluminum stock and make a "sandwich" off the tank straps. I have neoprene between the outer flat and the bracket on the pump to aid in reducing noise/vibration. This was taken before I added a large Fram fuel filter inline.
I still need to re-route the hoses and swap to braided stainless as all the parts are sitting on the workbench.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #4 of 8 (permalink) Old Feb 17th, 11, 07:09 AM
Ed
BigBlock1969RS's Avatar
Pretty much the same here, made a "T" bracket to mount the pump to using rubber grommits to try to isolate the pump from the body of the car.
Sorry for the blurry pics.
Ed
BigBlock1969RS is offline
post #5 of 8 (permalink) Old Feb 17th, 11, 08:23 AM
And mine was less fancy than the rest.
If you take Steiner's picture, look at the two left screws, I installed the pump up on the incline, bottom would be flush with his bracket.
post #6 of 8 (permalink) Old Feb 17th, 11, 09:57 AM Thread Starter
Steiner, how low does it sit below the tank? Hate to be a pain but would you have a picture at ground level from the back of the car looking forward?
post #7 of 8 (permalink) Old Feb 17th, 11, 05:54 PM
Steiner
No problem. By the way, the tank strap anchor on the left had come free so I needed two of those bolts anyway ha ha.
I think I'm going to cut the mount so it'll sit a little higher and also put the pump and filter on the front side of the tank like the other guys have. I was thinking about road debris when I did it this way. Also, my ghetto return that I put in the sending unit didn't work out too well so now there is a bulkhead fitting just above the tank seam.
It looks pretty low but if you look from this angle you can see it's several inches above the bottom of the rear end.
'69 Camaro
500hp/538lbft
Steiner is offline
post #8 of 8 (permalink) Old Feb 20th, 11, 04:22 PM Thread Starter
Thanks guys!
