motor mount plates - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 23rd, 11, 02:43 PM Thread Starter
george
motor mount plates
Ok I have a non a/c 68 camaro with a small block and th350. Just replacing the small block with a LSx motor. Leaving built th350 in it's place for now.
Now for the question Which motor mount plates am I needing for the LSx to sit at the same postion as the small block so the trans will bolt up?
I have been told stock and also 1" setback.
I bought a set of Hooker headers for the swap also. Trans is the only thing not moving.
firstgenguy is offline
post #2 of 4 (permalink) Old Feb 24th, 11, 03:18 PM
Re: motor mount plates
Hooker mounts place the engine in the stock position as far as I know. Be careful with your heater core nipples.
don
dhutton is offline
post #3 of 4 (permalink) Old Mar 22nd, 11, 09:22 AM
Nevin
I used these for the adjustability factor... http://dirtydingo.com/store/product_...oducts_id=1318
Check out my body work thread here...
I know I know it's slow going. But I, like most don't have enough time. lol
NOR_CAL_67rs is offline
post #4 of 4 (permalink) Old Mar 22nd, 11, 05:35 PM
I believe you want 1" set back for the same placement which, as was stated, puts you on the firewall so do a firewall block off plate or put in a big block heater core.
Ishmael is offline
