Inglese ezi efi stack injection - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 12th, 11, 02:35 AM Thread Starter
Gav
USA69Z's Avatar
hi , i am seriously considering purchasing a ezi efi stack system from inglese to put on my 69 camaro sbc .. The problem im having is there 50mm trumpets or tubes are level with my hood at 10 .5 inches total. Is there a manifold that is lower that has the common plenum for vacuum lines available?
any one have any experience with this setup?
I can get a local product here in australia from 'stack injection' that is a cross ram setup (lower) but it uses the haltech platinum 500 ecu and i like the simplicity of the fast ez efi setup for tuning etc.
how much more work is the haltech setup and tune?
Gav
RHD 69' 8 STACK INJECTED 383,FAST ECU, TREMECT56 6 SPEED, ATS ,SPEEDTECH, QA1s, HOTCHKIS, RUSHFORTHS , MOSER POSI 3.7, MAGNAFLOWS, ETC ETC
USA69Z is offline
post #2 of 3 (permalink) Old Mar 12th, 11, 05:36 AM
BILL
SPARKY69's Avatar
Re: Inglese ezi efi stack injection
stunning ride you have..
its going to be hard to fit that set up under your current hood?
these set ups are amazing and easy to use or dial in..
is your subframe stock?
which motor mounts/frame stands are you running?
not sure if there is other intakes avail or not?
drop engine or raise hood?
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #3 of 3 (permalink) Old Mar 13th, 11, 12:35 AM Thread Starter
Gav
USA69Z's Avatar
thanx Bill, all the motor mounts are stock.. and i have the height of the 2 systems at 10.5 inches with 50mm stacks (inglese) or 9inches if i use the crossram design injestion .. My hood clearance is exactly 10.5 inches. But i could have more if i notch it a little into the cowl hood space.
im hoping some-one here has used a 'haltech' unit .. as that comes with the kit with crossram.
Gav
USA69Z is offline
