Glenn's Performance Sleeper Tank - Team Camaro Tech
post #1 of 22 (permalink) Old Mar 25th, 11, 10:52 AM Thread Starter
Randy
rs1968ss's Avatar
Anyone have any input on these tanks?
http://www.glennsperformance.com/pro...roducts_id=191
-Randy
rs1968ss is offline
post #2 of 22 (permalink) Old Mar 25th, 11, 01:34 PM
foreverlookin's Avatar
Re: Glenn's Performance Sleeper Tank
Would have been nice if they had a bit of a write up on each....
foreverlookin is offline
post #3 of 22 (permalink) Old Mar 26th, 11, 03:18 PM Thread Starter
Randy
rs1968ss's Avatar
Well, after talking to them, I pulled the trigger and ordered their sleeper tank.
-Randy
rs1968ss is offline
post #4 of 22 (permalink) Old Mar 26th, 11, 03:41 PM
Do the fittings have tubes that go to the rear of the tank ?
Otherwise they'll uncover on a launch....unless baffled ?
68 Camaro~LSx ~all motor
post #5 of 22 (permalink) Old Mar 26th, 11, 04:07 PM
Steven
stamatisg1977's Avatar
is that an EFI tank?? pump in tank??
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #6 of 22 (permalink) Old Mar 26th, 11, 04:17 PM Thread Starter
Randy
rs1968ss's Avatar
It has baffles and tubes. I told him my combo (Holley Avenger with external pump) and he said that I should have no issues running it to E.
Hopefully it works as advertised. I can't see paying $1200-$1600 for a tank. I realize that there are benefits of the pump in the tank as far as noise but that is a lot of extra money.
-Randy
rs1968ss is offline
post #7 of 22 (permalink) Old Mar 26th, 11, 07:34 PM
Jack
X2 Is one an EFI tank? I came across their website searching for EFI tanks. Cant tell though....
67 RS
Royal Plum/Parchment
6.0 LSX 4L80e
06 corvette Z06
machine silver
jackr is offline
post #8 of 22 (permalink) Old Mar 27th, 11, 07:03 AM Thread Starter
Randy
rs1968ss's Avatar
Pumps are not in the tanks but support EFI. (according to the vendor). I'll take pics when it arrives.
-Randy
rs1968ss is offline
post #9 of 22 (permalink) Old Mar 27th, 11, 09:06 AM Thread Starter
Randy
rs1968ss's Avatar
I do have a question about venting. I have heard that I can just cut the feed line on my existing sending unit's feed tube and use that as the vent for this new tank.
Thoughts?
-Randy
rs1968ss is offline
post #10 of 22 (permalink) Old Mar 27th, 11, 12:36 PM
scblucam's Avatar
Seems to me you would have to remove the suction line to the botom of the tank for it to vent properly, but that is a viable idea if you can run it to a charcoal filter somewhere in the back.
68 302 M20 - 85 IROC Z
scblucam is offline
post #11 of 22 (permalink) Old Mar 30th, 11, 06:46 PM
Bob
MileHigh69's Avatar
Please post results using this tank. I am in the same dilemma.
_______________________________
69 Camaro, Air Ride Suspension,
Procharged HO 454, 700R4, 12 bolt with Yukon axles, 3:73 gears posi, Pypes 2.5" X pipe with Borla XS mufflers. Retrotek Speed EFI, Ridetech suspension.
Rushforth rated X with Toyo tires. MSD 6 ignition.
Wilwood 6 piston Dynalite disc brakes with Hydratech booster.
MileHigh69 is offline
post #12 of 22 (permalink) Old Mar 30th, 11, 07:14 PM Thread Starter
Randy
rs1968ss's Avatar
The tank is supposed to ship on Friday. I still have a little ways to go before I fire up the motor and get it back on the road. Might be another month or so but I'll let you know.
-Randy
rs1968ss is offline
post #13 of 22 (permalink) Old Mar 30th, 11, 07:41 PM
Steiner
Thoughts?
Randy, it looks like you retain your factory sending unit and would do as you describe and just cut the pickup tube off of the inside. However, I'd be concerned about how to keep fuel from sloshing into it when the tank is full.....seems like you'd want to cut the portion off that curves down to the tank seam and run a line up along the trunk pan to elevate it. That's pretty much why I put my vent in the filler neck and ran the line straight up into the trunk to a charcoal can. I couldn't figure out a way to do the vent under the car and get the line set up so that all of it would be above the tank.
They've got a good description on their sumped version of the tank and need to follow suit on that sleeper tank. They show the tank for $390 and then under options it says stainless + $100. The if you look just under the tanks it says the stainless one is $600. At any rate, it looks like they're taking a $90 Spectra tank, cutting out the corner, and then putting their gear in it. If they've got the baffling figured out to where it works it might be worth the $300 mod price to not have to figure it out and then do it on your own. I'd be interested in seeing a pic once you get it.....I bet you can get a good shot down the sending unit hole.
'69 Camaro
500hp/538lbft
Steiner is offline
post #14 of 22 (permalink) Old Apr 13th, 11, 10:03 AM Thread Starter
Randy
rs1968ss's Avatar
The tank showed up last night. It is going to be really tough to get a picture of the internals. It looks like there is a box built up in the corner where the feed and return lines are. You can't really see anything else.
They recommended using -10 feed and -8 return. I bought their filters with -10 on each side but am struggling to find -10 adapters for my fuel pump. The pump has 10mm threads. Holley makes 10mm to -6 and -8 adpaters but nother -10.
Any thoughts/suggestions? I've left Glenn's a message but have not heard back yet.
-Randy
rs1968ss is offline
post #15 of 22 (permalink) Old Apr 13th, 11, 05:31 PM
Steiner
I don't think you can get a -10AN adapter in a 10mm thread. You can probably just put the -8 in it and then use a -8 to -10 coupler. If the Holley pump has 10mm fittings than it's a good bet that -8 line will support more power than the pump will.
If you're going to run -10 line I take it the dyno chart on your webpage is not current?....
'69 Camaro
500hp/538lbft
Steiner is offline
