Accel DFI Troubleshooting - Team Camaro Tech
post #1 of 1 (permalink) Old Apr 8th, 11, 02:44 PM Thread Starter
Jon
Hello All. I bought an Accel DFI Gen 6 kit from a friend at work and I am having trouble with it. The directions are not all that clear on hooking up the MSD box. My setup is this: I use a msd crank trigger setup on the balancer and it hooks to the ecm on the correct wires. I use the distributer as a cam sensor and it hooks to the computer and to the coil wire. The ECM has a white wire coming out of it that I hooked to my msd 6al box on the trigger (white wire). So the only hookups to the msd are the normal power/switched power, ground, white trigger wire, and the coil. I do not get any spark and I dont think the injectors are firing either. I have checked the fuses and normal stuff. Any suggestions? Anyone familiar with the Accel kits?
One last thing in case it helps. My fuel pump kicks on for about 2 seconds like it is supposed to but it only does it sometimes. Other times I can hear the relay but it doesnt kick on.
Jons69chevy is offline
