l.s. conversion parts suppliers and cost - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 14th, 11, 05:44 PM Thread Starter
kt
kelly
Well i feel i need to try a l.s. conversion on my 69 camaro, currently it has a 396 with a m-21 in it. I have a gm performance ls-6 crate engine and a 4l60e trans out of a 2007 2 wheel drive truck. My car has factory gauges and 4 sp console, its a original looking r.s. ss car. i cant prove that its a factory car.
I need help with locating parts suppliers that have know parts that work as being in canada all will have to be sent across the boarder and sending parts back sucks. Also the costs here are my findings
headers and motor mounts aprox 1000 bucks
wiring and ecm and tune aprox 1000
drive set up for non a/c….using oem parts..300 ish
aftermarket fuel tank…600…or use oem tank and in frame pump?
rad and fans..used….unknown cost.
aftermarket stall for 4l60e….600
oil pan, the engine has a cts-v oil pan, which wont work it seems with out mods
what about making the factory gauges work, the speed will req a box of some sort, or a tail shaft( another expense) what about the rest of them, the tach ??
So what say you….any names of manufactures that are known to provide good parts and service??…any ideas on the costs on the above?? to high to low?
i have the engine and have the trans, although i have yet to rebuild the trans, i am just in the beginning of getting info and feel the sometimes to much reading is a bad thing…lol…
sorry for the long post ...
kt is offline
post #2 of 3 (permalink) Old Jul 20th, 11, 08:07 PM
Hugh
Re: l.s. conversion parts suppliers and cost
see if this helps
http://www.ls1tech.com/forums/conver...you-think.html
Blevinator is offline
post #3 of 3 (permalink) Old Jul 23rd, 11, 03:12 PM
Lee
Hooker, Edelbrock make motor mount kits and headers to stick an LS motor in a 1st Gen. BRP, I think does as well.
Rock Auto I think sells the fuel tanks you are looking for. Prices are all over the map and some are well north of $1k. It really depends on what you want. If you are handy with a welder, you can buy a stock tank and make one suitable for fuel injection.
The website Blevinator recommends is about the best one out there for getting research on this. There are several good threads over there about 1st gen Camaro conversions too. I would do a lot of reading over there before spinning a wrench. Some of the threads started their conversions before aftermarket parts caught up with the trend so...dont' accept their solution to the problem with doing research to see if someone else has come up with a better mouse trap. You may want to peruse Chevy Hi Performance and Hot Rod's websites to see if there are tech articles out there to help you out.
I don't now if emissions are a concern where you are at, but GM does sell a crate LS-3 geared for hot rods along with the appropriate accessories etc. It makes 430 hp and is emissions legal with CARB approval etc. I would check out Scoogin Dickey Chevrolet or Pace Chevrolet and see what they offer. All the car mags had a big spread about it last fall.
69Project is offline
