454 Gen IV retrofit to EFI - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 3rd, 12, 06:59 AM Thread Starter
I'd like to install EFI on my 73 Vette with a 454 Gen IV motor. I have the fuel injection parts from a Gen VI motor.
Can anyone give me any guidance on any issues or problem with making this swap?
Thanks in advance!
Rich
techsol is offline
post #2 of 2 (permalink) Old Aug 3rd, 12, 11:03 AM
Vintage 68's Avatar
Thumbs up Re: 454 Gen IV retrofit to EFI
I don't think you are going to run into any major 'issue or problem' - just choices, that will cause or correct them
Would need to know more about the system(s) you intend to use;
Year it's off of.
Control system you intend to use.
Level of control you intend to facilitate for. (ECM interface with other systems, like trans.)
Level of performance you're intending to achieve.
Amount of work you can do yourself.
Your level of understanding and comfort in working with EFI systems.
Amount of outside help you intend to make use of (programming as needed and etc.)
Amount of work you intend to do to get clearance for the system with the hood. (changes intake air routing and can cause 'issues')
Type of fuel supply system you need, intend to use and what mods you intend for original system.
The above answered/answers will give you a good idea of how planning your project will avoid the normal issues that come up when you take on these type of projects.
1968 Convertible
Some trucks
Vintage 68 is offline
