what diameter is LS1 fuel pump? - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 6th, 12, 12:13 PM Thread Starter
Craig
Hey all. I thought I read on here before that you could use an LS fuel pump with older EFI tanks. I'm looking at a mid80's cutlass tank. I think they had EFI. Anyone have the diameter of an LS1 fuel pump module so I can see if it fits? Thanks!
wgearhead67 is offline
post #2 of 4 (permalink) Old Oct 6th, 12, 12:34 PM
Vega$69's Avatar
Re: what diameter is LS1 fuel pump?
Different cars and different years have different fuel pumps. Corvette, Camaro all different,
Pre 2000 different then after.
What exactly are you trying to do?
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 4 (permalink) Old Oct 6th, 12, 01:42 PM Thread Starter
Craig
Yeah I had read there were pressure differences with earlier EFI and that the pumps vary some by application, but I was wondering if the diameters and lock mechanism were the same (figuring the length of pump assembly might have to be altered).
I'm putting an LS1/T56 in a 67 Camaro. I have read about people sumping their original tanks and using an external pump, but I don't see a robust way to mount the pump lower than the tank as the tank already sits so low in car. I've read about guys welding the new in-tank pump interface to the top of their tank and all of the sumping and starvation issues they have. Then of course there are the large number of folks that buy the aftermarket EFI tanks, and it seems they all have issues (and costs ranging $600-$1200 or more). I would really like to avoid $1200 for a fuel tank.
So I was thinking an older OEM tank probably has the sumping and baffling that would work. Came across this mid-80s Olds tank that is about the same size as the 1st gen tank and even has the inlet in the rear, so was considering it. That's what prompted the question...
Thanks for the quick response and interest!!
post #4 of 4 (permalink) Old Nov 3rd, 12, 01:22 PM
I bought a repro tank and had a friend tig weld in a recessed mounting pad for this: http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
While at it, he also added a recessed mounting pad for an autometer universal fuel sender.
I couldn't justify a $1000+ tank so went this route for around $400. The idea was if this didn't work out I'd pony up for a big $$ tank but so far so good.
It's been running since January with a couple thousand miles on it and haven't run into any problems. I don't autocross it or race it so it doesn't see super hard cornering, though with that 'pool' the pump sits in I'm not sure it would encounter any starvation.
67 with ls1
67 rs mutt
fool injected is offline
