Holley EFI Coolant temp location - Team Camaro Tech
post #1 of 9 (permalink) Old Oct 18th, 12, 06:17 PM Thread Starter
Timothy
Im a newb to EFI, among other things
Will the passanger / rear coolant passage on a Edelbrock RPM air gap manifold yield correct temperatures for the computer?
My 69 RS/SS 396 Project -
"I may be dumb but I aint stupid"
Microgiant is offline
post #2 of 9 (permalink) Old Oct 18th, 12, 06:41 PM
Steiner
Re: Holley EFI Coolant temp location
It's not advised. That port is a deadhead so there is not constant coolant flow. It think it is designed so that you could install a crossover pipe between the two rear ports. I would put it in the head if the harness will reach. I run mine in the front intake with a bushing (1/2 to 3/8 NPT). The only thing I don't like about it is that the intake warms a lot slower than the head/combustion chamber so setting up my cold fuel enrichment was a pain. My cold fuel settings affect the entire fuel map so when they were right to get it warming up at idle they were way too rich if trying to drive off so it would rich misfire like a beeyotch. But, on my unit you can change all that stuff it just took time and I had to figure in some offset and have all extra fuel kick out by the time the intake came up to 100 degrees instead of 140 degrees which was stock setup. Sorry, just rambling.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 9 (permalink) Old Oct 19th, 12, 04:38 PM Thread Starter
Timothy
I may also have to customize my fuel map beacuse I dont beleive my Dart Pro 1 BBC heads have a provision for a temperature sensor.
Any other ideas?
post #4 of 9 (permalink) Old Oct 19th, 12, 05:44 PM
Steiner
That's all I got. You can try the rear port if you want or use a bushing for one of the front ports on the intake. Your EFI system may not have the issues that mine does. It's a combination of the intake warming up slower than the head and their programming for cold enrichment.
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 9 (permalink) Old Nov 14th, 12, 06:41 PM Thread Starter
Timothy
I am using the front port for now. Ive seen a few other cludgey solutions. I have to have my laptop connected to see the temp but so far I have not exceeded 185. I really hate loosing the stock sensor even though its not digital. I will update if i figure something better out.
post #6 of 9 (permalink) Old Nov 14th, 12, 07:22 PM
Steiner
You can try one of those water necks with the NPT port in it to get your gauge back. Also Jags That Run can make a hose connector with NPT port that you could insert in one of your heater hoses if you still have a heater core. You'd have to ground it though. Details are here:
http://www.jagsthatrun.com/Pages/Par...sHoseTees.html
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 9 (permalink) Old Nov 15th, 12, 12:09 PM
Tim
If the rear port sits in coolant...I think it would have sufficent flow past whether it was a deadhead or not (ie the fluid doesn't sit in any one spot).
Actual engine temp isn't really critical...but tuning it to the appropriate warming curve is. The cylinder head would be ideal, but I use the intake port as well (front though).
Between the two-EFI and interior gauge, I would run the EFI to the front and the guage to the rear.
Good luck!
1969 Nova SS 350
EFI 407/TKO600/4.11
11.43 at 121 MPH
L48M20 is offline
post #8 of 9 (permalink) Old Nov 21st, 12, 05:26 PM Thread Starter
Timothy
That sounds like a plan, Does anyone have a part number for a 1/4 NPT temperature guage?
post #9 of 9 (permalink) Old Nov 22nd, 12, 06:49 AM Thread Starter
Timothy
Actually I mean a 1/2"
