Car stalls after 10 minutes - Team Camaro Tech
post #1 of 5 (permalink) Old May 24th, 13, 07:40 PM Thread Starter
Bob
MileHigh69's Avatar
I got my car back after it was in Auto body jail for 11 months. It starts fine but after about 10 minutes it stalls rather abruptly. It will cut out then run and cut out. It has fuel injection on a HO 454. Voltage is 13-14 volts, fuel pressure looks good. It almost acts like ignition. I was wondering if it could be a bad O2 sensor also. Any thoughts on what it could be?
_______________________________
69 Camaro, Air Ride Suspension,
Procharged HO 454, 700R4, 12 bolt with Yukon axles, 3:73 gears posi, Pypes 2.5" X pipe with Borla XS mufflers. Retrotek Speed EFI, Ridetech suspension.
Rushforth rated X with Toyo tires. MSD 6 ignition.
Wilwood 6 piston Dynalite disc brakes with Hydratech booster.
MileHigh69 is offline
post #2 of 5 (permalink) Old May 25th, 13, 03:58 AM
Time suggests temperature. Look for something that changes temp after 10 mins. Coolant temp sensor?
Sent from my iPhone using Autoguide
Melrose RS is offline
post #3 of 5 (permalink) Old May 25th, 13, 06:05 AM Thread Starter
Bob
MileHigh69's Avatar
Re: Car stalls after 10 minutes
Would a bad temp sensor cause the engine to shut down?
post #4 of 5 (permalink) Old May 25th, 13, 07:12 AM
Lynn
I know nothing about Retrotek Speed EFI.
I agree, it is most likely something temp related, but could be either in the fi or the ignition.
If your efi is like most, a bad O2 sensor or temp sensor would not likely be the culprit. Both would cause issues, but not likely an abrupt stall. If your fuel pressure is good, I would look at the ignition first.
Lynn
bilodeaulynn is offline
post #5 of 5 (permalink) Old May 29th, 13, 06:16 AM Thread Starter
Bob
MileHigh69's Avatar
It turned out to be a bad coil. Thanks for the help.
