5.3 or 6.0 LM7 or LQ4 Truck Engine - Team Camaro Tech
post #1 of 41 (permalink) Old Jul 28th, 13, 10:10 AM Thread Starter
Given a choice of either, which would you choose for a 68 Camaro swap. The LM7 costs about $1000.00 the LQ4 about $1500.00.
I am almost ready to pull the trigger on a "dropout" . I realize a LS1 from a Camaro, all aluminum would probably be the best choice, but most of those are going for $2500+.
Any of them would still require motor mounts, harness mods, headers, drive system mods, etc....
I saw Ryan's thread on his LQ4 swap, and glad he paved the way with such detail.....
Thoughts?
Thanks.
jblakes is offline
post #2 of 41 (permalink) Old Jul 28th, 13, 12:41 PM
Bob
Re: 5.3 or 6.0 LM7 or LQ4 Truck Engine
I'd go LQ4 (LQ9 if you can find one)- like they old saying goes, there's no substitute for cubic inches.....
What are your plans for the engine- keeping it stock or building it up? I went with an LQ4, a Z06 cam, and an LS1 intake.
BobKovacs is offline
post #3 of 41 (permalink) Old Jul 28th, 13, 01:04 PM
Tory
Camaros-n-Chevelles's Avatar
What is the casting number on the heads?
I just purchased a LY6 for my 55 Nomad. The motor has 823 Casting rectangular port heads.
Tory
1968 Camaro Coupe
1964 Malibu SS Unrestored 36,000 Mile Survivor
1964 Malibu SS Hardtop
1966 Chevelle SS 396
1968 Malibu L-79, 1 of 4082 ~ SOLD
1955 Chevrolet Bel Air Unrestored 15,000 Mile Survivor
1955 Chevrolet Nomad
1984 Hurst Olds with Factory Sunroof, 1 of 99 ~ SOLD
1992 Camaro 396 LS, 4L60, 9" Posi w /3.50:1 Gear Set
Camaros-n-Chevelles is offline
post #4 of 41 (permalink) Old Jul 28th, 13, 01:40 PM Thread Starter
My plans would be for a "mild" build.....nice street cam, headers and intake.....
I do not know the casting numbers on the heads, engine is not located in my area, I would have it shipped.
jblakes is offline
post #5 of 41 (permalink) Old Jul 29th, 13, 07:13 AM Thread Starter
Bob,
Why the LQ9 over the LQ4? Because of the electronic Trottle body? The cost difference is $500 ..worth it? Do you have a part number for the Z06 cam? Does it require stiffer springs? Lifters?
jblakes is offline
post #6 of 41 (permalink) Old Jul 29th, 13, 08:13 AM Thread Starter
Bob, I also forgot, the LQ9 has a higher compression ratio....so same question, is it worth the extra expense in your opinion?
thoughts from anyone else?
jblakes is offline
post #7 of 41 (permalink) Old Jul 29th, 13, 09:58 AM
Brent
67Rally's Avatar
LQ9 has higher compression (flat top pistons vs dished), and floating wrist pins/stronger rods. The earlier LQ4's had a press fit wrist pin. Some '99-00 LQ4's had the iron heads instead of the 317 aluminums.
The compression doesn't make a huge difference, +20hp/+10tq between the two, and I think some of that is in the tune.
The difference between an LQ4 and LQ9 was about $200 when I bought mine, so I went with the LQ9. I'd lean towards a 6.0 rather than a 5.3, just for the cubes.
67Rally is offline
post #8 of 41 (permalink) Old Jul 29th, 13, 09:58 AM
Bob
The higher compression ratio is the reason for the LQ9 over the LQ4. Is it worth the extra $500? Only you can answer that question.
If I remember correctly, the cam is the 2002-2004 LS6 cam- part # 12565308. It does require new springs. Be careful when ordering springs- they sometimes list the part number for a single spring, and when you multiply the cost of that spring x 16, the total cost is ridiculous. They sell the same springs in a box of 16 for about $60. You just need to find a parts guy at a local dealership who knows what he's doing so he orders the set instead of 16 individual springs.
Also, you'll need a special spring compressor for the LS- the standard ones down't work.
post #9 of 41 (permalink) Old Jul 29th, 13, 09:59 AM
Brent
67Rally's Avatar
Also figure out what you are really going to do with the engine. If you are going to buy a new harness and swap out any of the accessories, it doesn't make sense to buy a complete dropout. I did, and I ended up replacing almost everything and selling the take off's on eBay to recoup some cost. If I could do it again, I'd start with a long block and go from there.
67Rally is offline
post #10 of 41 (permalink) Old Jul 29th, 13, 11:57 AM Thread Starter
Thanks for all the info so far guys.....I have lots to think about. Brent, I hear what you are saying about the harness. I had actually thought about modifying it myself. I am familiar with circuits and soldering and www.Lt1swap.com has some real good info about diy.....
I need to look at the prices of longblocks and compare ....any good sources?
jblakes is offline
post #11 of 41 (permalink) Old Jul 29th, 13, 12:07 PM
Brent
67Rally's Avatar
It just wasn't worth it to me to try to adapt a harness. After all the other expenses I had during the project, the last thing I wanted to do was turn the key and not fire up (still happened, but it was my own fault).
I got my engine through Bow Auto Parts (http://www.bowautoparts.com/), out of Bow, NH. I found them on eBay: http://stores.ebay.com/bowautoparts . They were local enough that I just drove up and picked the engine up, saving on shipping. They do full dropouts though, not long blocks. I just checked their eBay inventory, and prices look about $200 higher than when I bought mine over the winter.
For the harness, I used PSI Conversion out of NJ. Jon is the owner, and very responsive to e-mails and phone calls.
67Rally is offline
post #12 of 41 (permalink) Old Jul 29th, 13, 01:05 PM Thread Starter
Bowauto is where I have been looking at them....Hard to believe they have gone up that much in a few months.....
Anyone with other thoughts on Longblock vs dropout?
Thanks for the responses on the difference between LQ4 and LQ9. That helps alot....
jblakes is offline
post #13 of 41 (permalink) Old Jul 29th, 13, 02:41 PM
Brent
67Rally's Avatar
I got mine mid January, and jumped on a lower mile LQ9. It was priced better than some of his others, struck a deal on the phone and picked it up the next day.
Do you care what the engine looks like? You said you're going to do an intake (good thing, the truck intake is ugly). The truck alternator sits pretty high compared to the other setups. Will you change the brackets to move it?
If you're going to keep it stock and mod the harness, buy the drop out. If you're going to do cam and intake (heads too?), harness too?, then maybe you don't need a complete engine. It just depends on what you're final goal is.
I'm the wrong person to ask, because I literally stripped the motor and started from scratch. I degreased it, painted it, did heads/cam/intake, new alt/ps pump & brackets, starter, harness, fuel rails, injectors.....Don't be like me, know where you want to end up. With that said, I couldn't be happier with final outcome.
67Rally is offline
post #14 of 41 (permalink) Old Jul 29th, 13, 02:54 PM
Vega$69's Avatar
I would buy the complete engine and harness with the ECM. Go the LQ9 for the higher compression. Then you can just add a better cam. I would not use a ZO6 as there are way better cams out there for not much more $.
The harness is super easy to chop and the ECM programming is a cinch.
That said a way better way to go is to use the new MSD Atomic set up. No Computer, NO Wiring Harness No tuning as it self tunes. Down side is it does not come cheap.
http://www.jegs.com/p/MSD-Ignition/M...33276/10002/-1
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #15 of 41 (permalink) Old Jul 29th, 13, 03:19 PM Thread Starter
I would probably clean it up a bit, which would include taking it apart for inspection. Only replace things that needed it. For now, as little as possible....then start saving again after the initial purchase...
Have no intention of purchasing new heads, just clean up the old ones....in fact, the stock cam will probably even be used for awhile, as noted above, to save cash.
As far as the alt. bracket, I do not see too much alternative to purchasing a different one, the stock one will not fit under the flat hood....
jblakes is offline
