67 LS1 procharger Rock Valley Tank - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 28th, 14, 08:53 PM Thread Starter
67LSRS
I am about ready to install the the fuel line plumbing on my 67 LS1 conversion. The engine is a forgeed bottom end decent cam and will be procharged using a D1SC and about 6lbs of boost to start with. I have the FAST XFI 2.0 using the new 1200 HP Throttle Body.
I have a Rock Valley tank Ls1 pump (Walboro according to Rock Valley). I have called a couple times to verify if the pump will be enough to supply the proper volume of fuel.
I keep looking at fitting holes on the tank which are only 1/4" pipe thread and I really think I may have a volume issue. Tech says with the #6 line for main line and #6 or #4 for return line I should have no problem.
Am I just worried for nothing or do I need to do something different to the tank for larger fittings? Anyone running a similar setup and has it worked or did you modify the tank/pump??
_____________________________________________
My 67 RS Project:
LS1, FAST XFI 2.0, Turbo 350, 12 Bolt 3.73's.
67LSRS is offline
post #2 of 2 (permalink) Old Jun 26th, 14, 08:15 PM Thread Starter
67LSRS
Re: 67 LS1 procharger Rock Valley Tank
well I called rock valley again and this time talked to Scott he is The man to talk to there He recommended the Walbro E85/gas pump that puts out 430LPH whcih I purchased and sent to him the hanger from my tank.
He built me a new hanger assembly with enlarged fittings and mounted the walbro to it. Very happy with upgrade and the service great guy and stand up company!
Now to get this plumbed and finish the wiring and get it fired up I can not wait!
My 67 RS Project:
67LSRS is offline
