Fast EZ EFI 2.0 ignition system question - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 21st, 14, 06:51 PM Thread Starter
Hey guys, I am finally installing my Fast EZ EFI 2.0 into my 68 camaro. My current ignition system consists of MSD 6al-2 Programmable, Blaster SS coil and MSD Pro Billet Distributer. After reading all the issues using the MSD DIstributer, I decided to just buy the FAST Dual Sync. My question is should I run the 6al-2 programmable still with the blaster ss coil or remove the 6al box? Or any other input, ideas or suggestions?
1968 RS/SS 496 Solid Roller, AFR 290, Pro Systems 1000, TKO600, 12 Bolt 4.11's
2001 Pewter WS6 is offline
post #2 of 5 (permalink) Old Aug 22nd, 14, 11:10 AM Thread Starter
Re: Fast EZ EFI 2.0 ignition system question
Well I called FAST and decided to leave the 6al-2 box in. The car fired right up and have no issues so far.
post #3 of 5 (permalink) Old Aug 22nd, 14, 12:19 PM
Robert
rtchaney's Avatar
What differences have you noticed vs carb? I've done a 1.0 install and thought it was great; especially the fuel economy (+4mpg)/fire up over the 750dp I had. Also, what are the functional benefits of FAST's dizzy?
- Rob
1968, 5 speed, Vintage Air Gen IV, American Auto Wire Update Series, Champion 4 Core Rad, BMR front w/ Koni's, BP Roller 383, Posi 8.2", Solid Frame Bushings
rtchaney is offline
post #4 of 5 (permalink) Old Aug 22nd, 14, 02:22 PM Thread Starter
I haven't driven the car as of yet, still doing some wiring. The car starts right up and idles perfectly. Throttle response seems crisper. I went with the FAST dizzy because all of the problems I saw people were having had different distributers and there problems went away after they replaced it with the fast dual sync. I figured I would play it say and go with what works.
post #5 of 5 (permalink) Old Aug 22nd, 14, 03:39 PM
Robert
rtchaney's Avatar
Good call. The programmable curves and lack of weights to stick seems like a great idea. Keep us posted friend!
- Rob
rtchaney is offline
