Help! Ram Jet 502 problem - Team Camaro Tech
post #1 of 3 (permalink) Old May 18th, 15, 10:48 AM Thread Starter
Jason
just fired up my Ram Jet 502 for the first time yesterday. It will not come off of 3000 rpms. It's in the break in period, and when the DTC switch is off, it revs to 3k, when you switch it on, it drops down to 1500-1800 rpms. No vacuum leaks, is it in the tune? TPS not reading correctly?
1967 Camaro Yenko Pro Touring Tribute (being built)
Follow my build
67YenkoJC is offline
post #2 of 3 (permalink) Old May 18th, 15, 07:15 PM
Re: Help! Ram Jet 502 problem
Had a similar problem with my Terminator setup. I had the target idle set too low to start with so it revved up to about 2500rpm. I had to increase my target idle a bit, adjust the throttle plates down a bit, conduct TPS reset, then restart and adjust from there. It took a few cycles but settled down nicely and only took a few minutes from start to finish. Hopefully this will help a little. Good luck!!
69 Camaro X44
408ci
Terminator EFI
AFR 195's
XE274H
T56 Magnum
4:10 posi
12 Bolt
bkerns925 is offline
post #3 of 3 (permalink) Old May 20th, 15, 05:20 PM Thread Starter
Jason
Found the problem, vacuum leak. Runs good.
Follow my build
