Exhaust heat after fi swap - Team Camaro Tech
post #1 of 11 (permalink) Old Mar 6th, 16, 03:48 PM Thread Starter
Kip
For those of you that have gone from a carb to an aftermarket FI sytem...
Have you noticed that your exhaust is running significantly hotter...?
I have recently installed a Holley Terminator system on my SBC 400. It replaced a 950 cfm ProSystems carb.
Engine specs:
Dart SHP block
AFR 210 ELIMINATOR
EDELBROCK PERFORMER rpm
STRAUB ROLLER
dur @ .50 231/238
lift 576/569
108 lope sep
Computer controls all timing events
25*initial
34*WOT
40* cruise
Air/Fuel ratio are
12.8 at WOT
14 at cruise
I have noticed significantly more exhaust heat since the swap. I realize that the system is still learning... but damn... I can smell the "hotness". I can feel in coming through the floor..when before it was not noticeable. It has kinda messed up the shiny coating on my Dynatech headers...
The plugs are a nice tan color with no melting or deposits. Way cleaner than the carb plugs. No exhaust residue on the concrete under exhaust..
Appreciate any feedback..
Kip
kv67ssrs is offline
post #2 of 11 (permalink) Old Mar 6th, 16, 04:59 PM
Re: Exhaust heat after fi swap
The engine being fueled by EFI, a leaner mixture than being carb'd, is making the exhaust hotter.
post #3 of 11 (permalink) Old Mar 6th, 16, 05:24 PM
I'd have o agree... lean (hotter) burn.
Mine was pretty unbearable on a 95*+ day, but now with an AFR meter and a better tune (still carb'ed) I can say it's a lot better....almost unnoticeable heat.
Idle in the 13 range once fully warmed up....but your numbers look right
ID:	140457   Click image for larger version
Name:	AFR Limits.jpg
68 Camaro~LSx ~all motor
post #4 of 11 (permalink) Old Mar 6th, 16, 05:58 PM Thread Starter
Kip
YUP... I am kinda stumped.... It was only 70* today... and my leg was hot... It would be miserable in the summer....
My carb is looking real good about now...!
Guess I will call Holley tomorrow....
kv67ssrs is offline
post #5 of 11 (permalink) Old Mar 7th, 16, 02:42 AM
How was the coolant temp ?
Notice any change ?
post #6 of 11 (permalink) Old Mar 7th, 16, 07:58 AM Thread Starter
Kip
coolant temp is the same.....
kv67ssrs is offline
post #7 of 11 (permalink) Old Mar 7th, 16, 04:54 PM
mike
Wow that is something I had not thought of. Mine is unbearable now with a carb.
bigblockragtop is offline
post #8 of 11 (permalink) Old Mar 8th, 16, 08:23 AM Thread Starter
Kip
I was toying with the idea of trying a different fuel map... one that is "fatter" overall....
kv67ssrs is offline
post #9 of 11 (permalink) Old Mar 8th, 16, 12:41 PM
Just remember, those numbers are NOT set in stone. They can not account for every brand/blend on the market
post #10 of 11 (permalink) Old Mar 12th, 16, 05:04 PM
DT
Donny
DT's Avatar
Your numbers really don't look that bad. I'm pretty sure 14.7 is optimal and is what the OBD II generation is set at.
DT is offline
post #11 of 11 (permalink) Old Mar 13th, 16, 07:46 AM
Vega$69's Avatar
Your numbers are good. Better running more effeciient and more heat.
I would leave it alone and install some heat shielding
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
