fuel sending unit modify for fitech efi - Team Camaro Tech
post #1 of 6 (permalink) Old May 24th, 16, 06:14 AM Thread Starter
planning on putting the fitech efi system with the fuel command center. my fuel sender is new but doesnt have a return line can i drill drill a 1/4 " hole and glue or solder a 1/4 return line has anyone done this
jdbr1 is offline
post #2 of 6 (permalink) Old May 24th, 16, 06:17 AM
Vega$69's Avatar
Re: fuel sending unit modify for fitech efi
I would buy a new 2 line sender
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 6 (permalink) Old May 25th, 16, 08:49 AM
Bill
I modified the sender on my 68 like you describe. I drilled and tapped a hole to 1/8npt, but had to use 2 fittings to be able to turn it to tighten and then it was taller than the feed line and hits the trunk floor, it is in and working and doesn't leak but it would be best to get a 2 line sender.
Bill
napabilly is offline
post #4 of 6 (permalink) Old Jun 9th, 16, 08:56 AM
Eric
I thought the fuel command center didn't require a return line to the tank. It has a return line to its own reservoir.
ERIC
67 Convertible, 350CID, TKO600RR, 3.73 Eaton Posi
ept000 is online now
post #5 of 6 (permalink) Old Jun 13th, 16, 05:09 AM
George
Gbauer's Avatar
It still requires it.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #6 of 6 (permalink) Old Jun 22nd, 16, 09:13 AM
Todd
I had to do the same thing you are. I chose to put a new 2 line sending unit in. Done and working well.
Bolero Red/Black 67 rs/ss, 350 4-sp, Deluxe interior, slowly becoming a restomod
Aqua blue/White 77 LT Type, Built 305 auto, in the restomod process, wife's car since high school.
67rssstodd is offline
