FiTech on 454 - Team Camaro Tech
post #1 of 11 (permalink) Old Jun 9th, 16, 12:15 AM Thread Starter
Lyle
FiTech on 454
I want to put efi on my car. Just got it out of paint jail and back on the road. First time I've driven it in 16 years got to drive it one day and lost second gear in my th 400. So I haven't bought it yet. Looking at the FiTech or Holly sniper. I will get a new tank with an in tank fuel pump and run another 3 /8 stainless fuel line. I've been reading every forum post I can find on the subject and would have ordered by now but have to get the tranny rebuilt.
I currently have a worn out Holly 850 dp and a drop base air cleaner on my bbc under a 2 inch cowl hood. I have a performer rpm non air gap intake. Looks like with the efi I can't use a drop base air cleaner. Has anyone else run into this issue. Wondering if it will fit under the hood.
Seems like most people with in tank pumps are pretty happy with these systems for the price.
akwolf is offline
post #2 of 11 (permalink) Old Jun 9th, 16, 05:30 AM
Vega$69's Avatar
Re: FiTech on 454
In tank is the way to go. I'd go with either the Holley or Fast efi
Vega$69 is offline
post #3 of 11 (permalink) Old Jun 9th, 16, 08:53 AM
Eric
Re: FiTech on 454
Why is that?
ERIC
67 Convertible, 350CID, TKO600RR, 3.73 Eaton Posi
ept000 is offline
post #4 of 11 (permalink) Old Jun 9th, 16, 12:50 PM Thread Starter
Lyle
Re: FiTech on 454
I was pretty interested in Holly Vega$69 looks like I'll have time to figure out which way to go. Tranny is coming out of the car today and my corvette ralleys are causing tire rub issues. Need to get a different back spacing and wheel width. Picking one issue at a time to solve. I will take a look at fast also. Had reservations with FiTech due to customer service issues. They haven't answered the phone from me.
Thanks for your opinion.
akwolf is offline
post #5 of 11 (permalink) Old Jun 9th, 16, 02:12 PM
Darin
ilikeike's Avatar
Re: FiTech on 454
I have a dropped air cleaner on my Holley Terminator efi, but it's a SBC.
Some of the TBI style EFI don't like a divided plenum intake,due to MAP sensor location on one side. If you have the milled out divider or and open spacer it may be ok.
Lots of Holley EFI questions answered here -> Holley EFI
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #6 of 11 (permalink) Old Jun 10th, 16, 08:06 AM
Re: FiTech on 454
In tank pump is the way to go in my opinion. Quieter and more reliable. I would not bother running a return line to the front of the car. Buy an LS-style fuel filter regulator and mount it on the frame rail close to the tank. It will pass a constant 58psi and divert the excess back to the return line to the tank. Inexpensive and available at any autoparts store.
Here is one with the AN adapters included:
LS Fuel Filter Regulator
An added bonus is that it is a filter and regulator in one.
Check the online instructions for the unit you choose to buy. Several manufacturers do not allow you to run hard lines to the EFI, so you many be running rubber AN6 anyway. In that case, you could use your existing hard line as your return.
68RS/SS Convertible L48 (350/295 Powerglide)
daverichard is offline
post #7 of 11 (permalink) Old Jun 12th, 16, 11:49 PM Thread Starter
Lyle
Re: FiTech on 454
Thanks daverichard. I've heard of fuel hammer issues with hard lines. Seems odd but I will look into that and the LS filter regulator. Hate doing things twice.
akwolf is offline
post #8 of 11 (permalink) Old Jun 13th, 16, 03:58 AM
Steiner
Re: FiTech on 454
The Sniper has a built in fuel pressure regulator. Go with something like a Tanks Inc setup with in tank pump. Keep in mind that some systems require a certain fuel pressure and might not have a user adjustable pressure value input for the fueling calculations so the LS filter/regulator is not an across the board solution.
Go with a single plane intake, dual planes have uneven fueling issues with TBI.
The guy who runs FiTech has a history of three or four different companies now where customer service eventually falls off the map. I know this is his third EFI company now. Holley, FAST, Edelbrock, QuickFuel et al will be there at some point in the future. However, even with those the best help you typically get on their forums is from customers or tuners....you have to call and talk to someone at the company if you want their help.
And above all get something that allows some level of user tuning.
'69 Camaro
500hp/538lbft
Steiner is offline
post #9 of 11 (permalink) Old Jun 14th, 16, 12:58 AM Thread Starter
Lyle
Re: FiTech on 454
Steiner, I was planing on going with tanks inc system. Seems like the best way to go. Sounds like a single plane intake will work better than my performer RPM. My horse power is about 550 and the fitech and Holly systems 4 injector versions advertise up to 600. That's getting close. But wasn't sure if one of the bigger systems would control poorly. Seems like they only have two injector sizes. I would like some level of user tuning. If the unit can't build a proper fuel table on its own I'll give it a try. Which systems can you tune your self.
Thanks for your help.
akwolf is offline
post #10 of 11 (permalink) Old Jun 14th, 16, 06:37 AM
Darin
ilikeike's Avatar
Re: FiTech on 454
The Holley Terminator can do some tuning with the included 3.5" touch screen,or plug in your laptop for full access to timing tables,fuel tables,IAC and everything else....The terminator ECU is the same as the HP ECU.
If you go with something like that, make sure you have a compatible distributer to take advantage of the timing control, like a GM small cap HEI,they're not too expensive, as compared to a new MSD.
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #11 of 11 (permalink) Old Jun 14th, 16, 11:27 PM Thread Starter
Lyle
Re: FiTech on 454
Did some reading on the Holly forum. Looks like the terminator is a pretty good system. Thanks for the heads up. A lot of knowledge on that system. Probably worth the price difference between it and the fitech.
akwolf is offline
