Holley Sniper wiring with Vintage Air - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 23rd, 17, 01:43 PM Thread Starter
Ted
I have a 1969 Camaro with a 383. I installed the Vintage Air system for cars without A/C. I'm now in the process of putting the Holley Sniper EFI on my car. The Sniper has optional connections for increasing the idle when the A/C kicks on and another to shut off the air at wide open throttle. Has anyone wired this combo? I called Vintage and they said most setups connect to the 12 volt power for the idle increase but the Holley instructions say to connect to a ground triggered A/C relay. I've tried calling Holley but have given up sitting on hold several times for 30 minutes. Thanks!
1969 Camaro, 383, M23Z from Jody's Transmission, Ford 9 inch w/3.00 gears, Ridetech tubular A arms, coil overs, 4 Link, Wilwood brakes, No Weeds cutouts, e-stopp, kick panels and package tray from The Shop LLC, TMI seats and one piece headliner, Vintage Air
SkeWest is offline
post #2 of 6 (permalink) Old Feb 23rd, 17, 02:06 PM
Re: Holley Sniper wiring with Vintage Air
I used the Edlebrock Proflow series FI with vintage aire. The throttle body , once set, acknowledges where idle position is and would use the he throttle body to trigger the on AC, I believe the IAC(Inlet air controller) mounted on the back of the throttle body, senses the vac drop. You should look for these input/outputs on your wiring mapping.
As for the AC cut off, I didn't have this as I was running a ZZ3 crate motor. Simple turning off the compressor with fan running could do the trick for you at the traffic lite.
Sounds like you got the wrong Holley tech .
TC # 349
zdld17 is offline
post #3 of 6 (permalink) Old Feb 23rd, 17, 07:51 PM
Darin
ilikeike's Avatar
I didn't use any of the a/c options on my holley efi, but I thought the instructions were pretty good in that area.
The holley forum is where you go if you want specific Holley efi answers. In fact,someone's probably already made a thread about it.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #4 of 6 (permalink) Old Feb 24th, 17, 10:24 AM Thread Starter
Ted
I'll try the holley forum. Thanks.
SkeWest is offline
post #5 of 6 (permalink) Old Feb 24th, 17, 03:53 PM
If I am following this right you can use an additional relay driven by the VA compressor signal to pull the Holley input to ground.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #6 of 6 (permalink) Old Feb 24th, 17, 08:16 PM Thread Starter
Ted
That's correct. I got a great explanation on the Holley forum for that. Still trying to figure out how to wire the WOT. Thanks for the help guys.
SkeWest is offline
