Timing control yes/no ?? - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 14th, 18, 02:07 PM Thread Starter
67 455 Bird ragtop's Avatar
I'm hoping to finally get my car running later this summer. As usual with projects things cause delays. Now technology has changed. I'm going efi. So I'm curious if I should run timing control or not. I currently have a new in the box Mallory vacuum comp 9000 8658001 distributor and a mallory 685 box. I liked the 685 box since it had starter retard.
But Now I'm debating to a timing control setup with MSD. Car will primarily be a cruiser with some track time. So am curious if I should switch to the MSD setup.
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline
post #2 of 2 (permalink) Old Apr 14th, 18, 03:57 PM
Steve69SS396's Avatar
Re: Timing control yes/no ??
If the ECU you are using with your EFI can't control timing I would highly recommend MSD's Grid. I ran one before I decided to go EFI. The ECU i went with is the Holley Dominator so I no longer needed the Grid. The Grid worked great and was able to record data which was great for the track.
Steve69SS396 is offline
