EFI w/Dual plane manifold ?? - Team Camaro Tech
 1Likes
  • 1 Post By Cunning69
post #1 of 10 (permalink) Old Jun 5th, 18, 06:13 AM Thread Starter
67 455 Bird ragtop's Avatar
I've read a few posts that the new EFI systems, Sniper/EFITech don't really like a dual plane manifold. I currently have an Edelbrock Performer RPM which is a dual plane manifold. What are my option?? Or is this not really an issue with the RPM ??
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline
post #2 of 10 (permalink) Old Jun 5th, 18, 06:39 AM
Robert
Re: EFI w/Dual plane manifold ??
Last weekend I installed the Sniper system on my Camaro with an LS engine. I also have the RPM dual plane manifold. So far acceleration and idle are very good, but I have only drove it about 100 miles since installation, it's still learning.
Couple things to note, I have not fixed any of these yet:
I get a whistling noise at about 30% throttle, seems this happens to a lot of people. The fix is to install a 1/4 inch or larger 4 hole spacer under the unit. It's not clear if this only happens on dual plane manifolds. https://www.efisystempro.com/sniper/...le-300-4004QFT
It is real touchy off idle, all four barrels open a once. The fix is a replacement piece of linkage that will give you progressive opening. Holley sells this for about $15. https://www.efisystempro.com/sniper/...ve-linkage-kit
My air cleaner has a drop base and it hit the fuel line. I think this will only happen if you use one of the two front fuel feed options. I had to do some cutting to get it to fit. Holley sells a modified drop base for 14 inch air cleaners that will work. https://www.efisystempro.com/sniper/...-black-120-511
Smitty68 likes this.
Cunning69 is offline
post #3 of 10 (permalink) Old Jun 5th, 18, 06:47 AM
It isn't an issue. Diesels, which where the first fuel injected engines, have nothing but a big open plenum with a throttle plate located somewhere to control the flow of incoming air. At wide open throttle they are open to the atmosphere, hence the need to provide a mechanical or an electric powered vacuum pump if you want vacuum for anything.
A carb requires vacuum pulses to work. the longer the runner the more torque you make down low, the shorter the more horse power you make up top. The RPM Air gap was designed to flow within 4% of a Victor Jr single plane while still retaining the advantages of the longer runners.
Direct injection or port injection will not be affected by manifold shape or runner length. If it is a Throttle Body containing the Injectors it is still just an electronic carb as the runners in the manifold are wet, not dry. As such it behaves like a carb, just a lot more expensive. Consider the Hilborn or Crower mechanical injection system used straight stacks for each port that were not connected in any way other than a throttle shaft with blades.
Big Dave
Larger Dave is offline
post #4 of 10 (permalink) Old Jun 5th, 18, 08:23 AM Thread Starter
Thanks for the feedback ..
post #5 of 10 (permalink) Old Jun 5th, 18, 08:40 AM
Robert
rtchaney's Avatar
I have about 3k miles on my Sniper system. Running and Edelbrock EPS with a 1" tapered 4 hole spacer. She's happy. I've seen vids online and had friends "mill" the plenum divider if they had issues and that seemed to rectify the problem. Simple dremmel mod.
1968, 5 speed, Vintage Air Gen IV, American Auto Wire Update Series, Champion 4 Core Rad, BMR front w/ Koni's, BP Roller 383, Posi 8.2", Solid Frame Bushings
rtchaney is offline
post #6 of 10 (permalink) Old Jun 5th, 18, 09:07 AM
Darin
ilikeike's Avatar
The Edelbrock RPM should have the notch in the divider so the MAP sensor port is getting good signal from both sides. I think some of the issues that were happening were on the dual plane manifolds with solid dividers and the the sensor location on some of the throttle body EFIs weren't getting good consistent signals or were getting pulses,reversion...
If you have room,throw a 1/2" open spacer on there.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #7 of 10 (permalink) Old Jun 5th, 18, 12:32 PM Thread Starter
Or cut a notch between the two sides while the intake is still off the car ??
post #8 of 10 (permalink) Old Jun 5th, 18, 01:31 PM
Darin
ilikeike's Avatar
If it doesn't have one yes.
Proven to be a good idea on the dyno. And why Edelbrock does it.
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #9 of 10 (permalink) Old Jun 5th, 18, 01:56 PM
Vega$69's Avatar
Yes. Even if carbed
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #10 of 10 (permalink) Old Jun 5th, 18, 05:21 PM
Rufas
Just remember a couple of things about EFI, manifold vacuum is less of an issue than with a carb, and, the single plane manifolds of olden days actually benefit from EFI, even throttle body type EFI systems. EFI must use the heat crossover passage, or, a water cooled plate under the throttle body, EFI doesn't like "cold" manifolds, or throttle bodies.
dave ray is offline
