FITech fuel pump circuit - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 19th, 18, 05:18 AM Thread Starter
67 455 Bird ragtop's Avatar
Does anyone know how this circuits works ?? Is it simply a key on circuit or does the ECM use something like a tach signal to trigger power to this lead?? Was looking to make sure if the engine stopped power was cut to the fuel pump. Or do I need to add an external switch to cut power to the pump if the motor dies or, and I hope it never happens, I'm in a wreck.
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline
post #2 of 3 (permalink) Old Jun 19th, 18, 12:21 PM Thread Starter
Re: FITech fuel pump circuit
Finally got a reply from FITech. The ECM controls the fuel pump. You get a 1.5 second burst at key on. Then as long as there is an RPM signal the fuel pump is energized. So no need for any extra fuel pump control switch
post #3 of 3 (permalink) Old Jun 19th, 18, 01:26 PM
Vega$69's Avatar
You are correct
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
