Sniper Install Questions - Team Camaro Tech
 3Likes
  • 3 Post By ZEN357
post #1 of 15 (permalink) Old Oct 24th, 18, 09:25 AM Thread Starter
I'm in the preliminary planning stages of doing a Sniper install on my 68 Camaro.
I picked up a TanksInc with internal walbro and plan to run the C5 FPR.
My car still has a 5/16" fuel line (been meaning to replace for a long time).
I'm planning to install a new 3/8" NiCopp line from back to front and make the flex connections with Goodridge 910 PTFE hose.
Since I have some flexibility it seems like maybe I should run the fuel line up the drivers side and leave the passenger side for battery cable routing when I finally get to moving the battery to the trunk.
A couple questions to start with:
1) Does anyone have pictures of where they mounted the C5 FPR on a 1st Gen?
2) Has anyone routed -6 up the drivers side? Any pics? Any issues with "room" near the drivers side firewall with brake lines, clutch linkage, etc?
Thanks!
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #2 of 15 (permalink) Old Oct 24th, 18, 05:12 PM
Re: Sniper Install Questions
Just my thoughts:
NHRA requires fuel line(s) routed on the outside of frame rails in case of any 'explosions' within frame rails, line is protected.
I would mount regulator just before fuel rail/injectors.
Run a return line, same route, to a Moroso return line adapter fitting between fill tube and tank, makes it easier, unless sending unit has a return nipple.
post #3 of 15 (permalink) Old Oct 24th, 18, 05:35 PM
Vega$69's Avatar
The Corvette regulator mounts just in front and above the fuel tank and you have a very short return line from there to the port on the walbro pump.
From there you run a single line to the throttlebody. On the sniper throttlebody and left it on the passenger side and then you would block the return side on the throttlebody
You can run it on the driver side but it will be a bit more challenging to ties into the throttlebody that is on the passenger side
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 15 (permalink) Old Oct 25th, 18, 03:09 AM
Brett
I have heard that there is now a in-tank pump with a built-in FPR. Is this something worth looking into?
Brett.....
P.S; so after posting this I went on the Tanks inc website and it appears I heard incorrectly. I did not find a Walbro pump with attached FPR. I did find a "Tank access door" that installs in the trunk floor in order to access the tank from the top. Great idea!
B....
Rockets Up In 2020!
Brettallen59 is online now
post #5 of 15 (permalink) Old Oct 25th, 18, 04:58 AM
Brett.....
B....
Ricks restomod tanks use a 5th gen Camaro fuel pump module with integrated FPR. A great solution imho. Or you can add a Vaporworx fuel pump controller so your pump only runs as hard as it needs to and not wide open all the time.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #6 of 15 (permalink) Old Oct 25th, 18, 05:17 AM
Vega$69's Avatar
Brett.....
B....
I looked at this access dor a while back.
2 things.
The floor of the 1st gen trunk is not flat. The fuel tank is tight against the bottom of the trunk.
If you cut the hole you can't screw it in because the screws will hit the tank. And it will not seat flat on the bottom of the trunk.
With a little R&D you could figure a way to make it work. I decided not to as it's easy to drop the tank. But an access door or panel would be nice.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #7 of 15 (permalink) Old Oct 25th, 18, 05:22 AM
I glue the access door to the floor with 3M 8115 panel adhesive. A few relief cuts and a little hammer and dolly work gets it sitting flat. A great addition, I use the DSE access panel in all my builds.
dhutton is offline
post #8 of 15 (permalink) Old Oct 25th, 18, 05:32 AM
Ed
This video may help answer some of your questions....
https://www.youtube.com/watch?list=P...&v=1mIhs4xahBY
dhutton, Vega$69 and Just 1 More like this.
ZEN357 is offline
post #9 of 15 (permalink) Old Oct 25th, 18, 06:39 AM
Vega$69's Avatar
The video is good. If you donít want an external pump you can use the Tanks inc EFI fuel tank and in tank pump. The Corvette regulator/filter does the same thing as the Holley but only cost $35
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #10 of 15 (permalink) Old Oct 25th, 18, 08:49 AM Thread Starter
Hi John
Thanks for the info. It sounds like youíve installed a few of these. From the video and what Iíve seen the return is at the rear on the left. Do you connect to the front right supply fitting in your installs? I was thinking about using the left rear.
Also any pics of your fpr mounted?
Thanks.
eville is offline
post #11 of 15 (permalink) Old Oct 25th, 18, 09:48 AM
Vega$69's Avatar
Sorry I had the inlets and outlets backwards
Looks like inlet on DS and return only on pass side
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #12 of 15 (permalink) Old Oct 25th, 18, 10:28 AM Thread Starter
With the DS connection. At the TB that’s why I was thinking running supply up the DS from the tank. I’m just a little worried about space under the Master cylinder and around throttle cable.
Maybe I’ll just use the PS front option location and feed from the rear and use a 180* fitting.
eville is offline
post #13 of 15 (permalink) Old Oct 26th, 18, 06:20 AM
Ed
Holley makes stainless steel gas tanks now for a range of models with all the provisions for the in tank fuel pump and sending unit, you could give them a call and see if they have what you're looking for, for your application.
ZEN357 is offline
post #14 of 15 (permalink) Old Oct 26th, 18, 10:24 AM
jeff
Has anyone used this, Holley 255 LPH OEM Style EFI Fuel Tank Modules
1967-69 Camaro/Firebird/Nova $329.00 on Holleys web site?
jkuro is offline
post #15 of 15 (permalink) Old Oct 28th, 18, 02:49 PM
I was wondering the same thing about the module. I used to do a lot of Drag racing, not much any more but I don't want to waste money and not get a reasonable solution. Anybody?
Dave69Z is offline
