1969 camaro tire size - Team Camaro Tech
post #1 of 12 (permalink) Old Feb 15th, 09, 01:09 PM Thread Starter
Tony
I have started back halfing my 1969 camaro and dont want to stretch the wheel wells.I want to use 29x18.5 or 29x12.5 prostreet radials.Anyone out there have some pics of this set up the could send to me?
Tony [email protected]
tillman is offline
post #2 of 12 (permalink) Old Feb 15th, 09, 03:19 PM Thread Starter
Tony
stretching feners
tillman is offline
post #3 of 12 (permalink) Old Feb 15th, 09, 03:26 PM
Re: stretching feners
69 is a lot easier than 67/68, there is a full radius, 69 cut in the center of 1/4 thru
crease, cut across top, cut down front and rear of wheel well opening, move front and rear peices to clear tires, cut the space out reweld those peices in make a 2-3-4 inch
peice to filll the wkeel well spread.
john68 is offline
post #4 of 12 (permalink) Old Feb 15th, 09, 03:43 PM Thread Starter
Tony
Do you think I need to stretch with a 29 tall tire?
tillman is offline
post #5 of 12 (permalink) Old Feb 15th, 09, 03:50 PM
Probally not I run 33" on a 68, I had to cut rockers an all 24' wide tubs, Borrow a tire and check fit.
john68 is offline
post #6 of 12 (permalink) Old Feb 15th, 09, 04:21 PM
Larry
hang on a few minutes, I told you I would post some pics 2 days ago and had to leave. Let me move my Chevelle out from under the rack and will post some pics for you. Do you want with or without tires? Mine is on the rack so the rear end is hanging down, but I have no problem at all with removing 29X18.5's on 15X14 wheels with a floor jack under the diff. Heres a couple for now from before it was taken apart... The body has been dropped down over the frame now, so it will be a lot lower> approx 1 1/2" in rear and 5" in front...
Sometimes it's better to let someone think your an idiot, than to open your mouth and remove all doubt...
ls427ss is offline
post #7 of 12 (permalink) Old Feb 15th, 09, 04:52 PM
Larry
Re: 1969 camaro tire size
did the pics I posted help, because it's raining, so unless you respond I will wait to put my car in the rain. If you need a specific pic of something let me know and I will try to help you out..
ls427ss is offline
post #8 of 12 (permalink) Old Feb 15th, 09, 06:16 PM
prostreet69camaro's Avatar
Look at this post. PROZ11 has the same tire you are talking about on a 69. PM him for some more pictures.
https://www.camaros.net/forums/showthread.php?t=151102
prostreet69camaro is offline
post #9 of 12 (permalink) Old Feb 15th, 09, 06:55 PM
Tony - When we backhalved my 69, the stock quarters took 29's nicely. Later went to 31's and had to stretch the front and rear fender lips to match the inner lips. Not that big of a job, and the 31's look better on my car than the 29's.
On page 2 of Pro Street, under "Video of our 69 BB", there is some footage that may help. Good luck.....................DC
DonCasanova is offline
post #10 of 12 (permalink) Old Feb 16th, 09, 04:46 AM
MARK
Send a message via AIM to PROZ11
Tony,
Let me know if you need any pictures. I would be happy to email you some or post them here.
Pro Street Z11 clone
YOUTUBE VIDEO:
PROZ11 is offline
post #11 of 12 (permalink) Old Feb 16th, 09, 02:17 PM Thread Starter
Tony
Thanks for the info I would like to see more pics
tillman is offline
post #12 of 12 (permalink) Old Feb 16th, 09, 03:35 PM
MARK
Originally Posted by tillman View Post
Pictures emailed...
YOUTUBE VIDEO:
PROZ11 is offline
